Have NO picture only sound WHEN TRY TO WATCH A dvd.help
    Sergeant:
  • 339 Answers
Do you use a scart lead? or hdmi cables if its a scart lead its either not pushed all the way in on the back of your dvd player or tv or a cable inside it has snapped have you got another one to try it??
if its hdmi again try another cable as new cables can be faulty
Hope this helps
John
Posted on Mar 12, 2011
Ok I purchased a philips dvd/vhs combo today and I can watch dvd and hear it great... but when I put a vhs in I get picture and no sound can anyone help me on this.. please
Check sound settings . If unit is set to Dolby change it to PCM. Most likely you have already went through other settings. If this does not work let me know the models of he unit and tv and what you have tried already and I will try to help
Nov 05, 2015 | Philips Televison & Video
Samsung hdtv, I have sound but no picture. This is an older tv, I have had it for about 6 years.
Have you try watching using a DVD player on your t.v if doesn't try watch on it using a DVD player but if still it doesn't have a picture but only sound perhaps there is a problem with your HDTV.
Jul 01, 2011 | Samsung PCL5415R TV
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
Same- get audit, no picture. HELP!!
It has to be something wrong with either the connection from the DVD video cable (yellow if your using composite av cables... green, blue and red if your using HDMI cables, or black with a round connector with little pins inside if using S-video), check on both the back of the DVD player where the cable comes out, and also on the back of either the TV or the receiver unit where the Video cable connects. If your cable goes from DVD --> Receiver --> TV, check both cables inbetween to ensure that they are tightly connected. Turn on your system as if your trying to watch a DVD, and when you hear the sound, wiggle the cables and see if you get a picture (having someone else wiggle and you watch or vice versa will be the easiest). If nothing comes up, then perhaps a cable is bad. Try replacing the cables with new ones, try the system now. If the cables didnt solve the problem, again, repeat the process of starting the DVD and then wiggling the cables. If still no picture, it might be internal issues with the connectors themselves. If your handy, you can try to take apart the devices and trouble shoot... but I would suggest calling Bose (or the companies that make your TV and DVD players) and see what steps they suggest you take.
Aug 10, 2009 | Bose Lifestyle 25 System
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Nov 22, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
Nov 16, 2008 | Curtis-Mathis CM19011 TV
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
DVD no picture but sound ok lg v8824w
hi there, had same problem, try turning on the player then holding the stop button on the remote for five seconds.this should restore the video picture
Jan 19, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
