Question about Troy-Bilt 21AE682L766 Big Red 10 HP Electric Start Rear Tine Tiller
I just purchased a 2011 big red troy built tiller and used it the first time today and it just starts acting like it is not getting gas and starts sputtering and dies
    Problem Solver:
  • 5 Answers
Problem with a lot of small engines no running right is the gas we have to use these days (ethonal) they were not made to use that gas
Posted on Mar 14, 2011
I have a Big Red Tiller started it up yesterday and it run fine for 5 minutes and heard a loud noise and it quit and will not start and has NO compression
probably broke the connecting rod. Common for machinery that sets for long periods without turning. Lack of lubricant since it is a splash type system
Mar 04, 2013 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Removing a gas tank from a Big Red Troy Bilt Tiller
remove the bands the other bolts are under the tank
Apr 18, 2012 | Garden
I bought a Troy built tiller. used once two years ago. then it has been sitting in a shed. It had old gas in it. I drained gas tank. I am getting a spark. when I pour gas in air breather, it starts, but...
I have had good luck using an engine starting fuel, sprayed into the air cleaner/intake. Any auto repair store will carry this product. CAUTION, HIGHLE FLAMMABLE!!!!!!! Many mechanics frown on using starting fluids, but I have a bad shoulder & that is what I do on the 3rd pull.
Louie Almond
Mar 27, 2011 | Troy-Bilt Pro-Line 160cc FRT Tiller
Troy built horse loses power when I engage tines into the dirt. What do I need to service?
sounds like you are trying to till too deep raise tines up a little with the depth gauge then till the same spot again and see if that helps
Mar 10, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
I HAVE A 8HP HORSE TROYBILT TILLER. I CAN NOT GET ANY GAS INTO THE CARB. I HAVE CLEAN GAS, NEW HOSES, AND CLEANED THE CARB. THE FLOAT IS NOT STUCK, ANY HELP?
have you checked to make sure your fuel shut off valve is turned on? If you remove the fuel line at the tank( with something to catch the gas) and your fuel shut off is turned on and you get no flow then something is clogging the fitting at the tank or inside the tank. You will have to remove and clean the tank. Let me know how you come out.
Frank
Sep 27, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
I have a troybilt pony tiller made on 1/22/79. On the transmission there is this number P35944...at least it looks like a P, not sure on that digit. Farther back on transmission near the tines, there is...
One is a serial number and the other is a part number ... This tiller was built in Troy, New York by Gardenway Manufacturing. Unfortunately, that family owned company is out of business. Whether there is still manufacturing in Troy New York, I am not sure but it is not the same company today as it was in 1979.
The assets, including the name, were purchased (and some sold) by several manufacturers, notably, MTD. The Troy products sold today are similar to the Troy products of the Gardenway Manufacturing. In my experience, there is no better customer service than that I received from GardenWay. The 6.5 was a big Pony ... I purchased a Horse about the same time and it is a 6.0 hp Techumsa. I am on my second engine and I wouldn't take twice the $ for it.
This tiller probably cost in the vicinity of $800.00 delivered.
There is a company in Canada that has specs on most Troy Models ... and access to lots of Troy parts, though thre are lots of other places that sell parts and have diagrams as well.
At one point Briggs was making 'flails' for the Troy Chipper Shredder ...
I hope this helps you with your tiller ... It is a teriffic machine.
Here is an interesting discussion board ... if you are interested: http://forums2.gardenweb.com/forums/load/tools/msg1108413014912.html
Thanks for your interest in fixYa.com
Jun 29, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Gas is coming out the exhaust. The engine will not start
Your float is either stuck or it has a hole in it and it is not floating. You can check yourself or take it back to rebuild person and have them check for you.
Jun 23, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Troy Built 6.0 HP stored for winter. Fired up and
Most definitely. You aren't getting enough gas, probably because the float valve is gummed up. Drain the gas, put in a little carb cleaner and a little fresh gas. Fire it up. Do that a couple of time if needed, then fill tank with fresh gas. Use a gas stabilizer like Sea Foam to prevent this.
Apr 05, 2010 | Troy-Bilt Pony Garden Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy-Bilt 21AE682L766 Big Red 10 HP Electric Start Rear Tine Tiller Logo
240 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
