Question about Craftsman Garden
Engin all of a sudden runs wide open and the throtle doesnt make any difference. Cables are still hooked up and moves the arm back and forth but doesnt change the engin speed. Any ideas?
    Sergeant:
    Champion:
  • 263 Answers
Those are not connected with engine
Posted on Mar 12, 2011
How to set goveners
As a rule there is a rod that runs from the governor arm to the carb throttle plate arm, sometimes there is a lot of holes to choose from to put that rod into. For most mowing type settings you push the throttle wide open on the carb and push the governor arm all the way full throttle and connect the rod by using whatever hole will let you or bend the rod to get into a hole. Your throttle cable will be connected to the governor arm with a spring ,this will allow the governor arm to swing back and forth to hold a steady RPM that you selected with your throtle cable. In a non mowing application like generators, the voltage output is regulated by the RPM so it would be adjusted by using a voltmeter and setting the governor to get 120 volts 60 cycle at the plug in, In the USA. Without the make and model it is hard to do more then talk theory but if you're handy this info will help.
Apr 07, 2016 | Garden
My briggs and stratton engine throttle cable and throttle body wont engage,always wide open
Are you sure it's not a new style Briggs that uses the 'throttle cable' just as a shut off? Many new mowers on;y start and run at High Speed
Jul 05, 2013 | Briggs & Stratton Garden
Renew throttle senser
you will see a small arm where the sensor goes into thortlebody, use your hand to open the throtle to see which way arm moves, you will look at sensor rear and see that arm, use a screwdriver to see how it moves and springs back. you want that arm on throtlebody to go on with tension. so get hole close then push on and turn to line hole up, this way there a small movement of sensor.
Feb 19, 2012 | 2004 Hyundai Santa Fe
Choke when set it will not releas or open back up. I can open choke by pressing in the tab that holds it closed and it pops back open
try holding throtle in the wide open postion and it releases the pin .adjust the choke with throtle in the full throtle postion
Aug 13, 2011 | Tomos Sprint Motorcycles
Pulled carerator to clean ,put back on and engin run wide open , think one of the is missing
check to make sure the governor was reconnected it will be a arm that goes behind the adjustment plate that's acts as a support for the barb it will have a spring and can come lose easily trying to install the carb if it comes lose the engine will run wiled and race hope this helps
Sep 01, 2010 | Briggs & Stratton Power Products 5,550...
TPS..?OR WHAT
I HAD A FRIEND AT OUR LOCAL DEALER TELL ME TO DISCONNECT THE NEGATIVE CABLES FOR ONE HOUR AND THEN RUN IT. SO FAR SO GOOD......NO PROBLEMS YET THANKS!!!!
May 12, 2009 | 1999 Dodge Ram
I need to how to connect the throttle to the carb on a briggs and stratton riding mower a diagram would be great.
Don't have a diagram. It's pretty simple, tho.
There is a throttle cable run from the throtle control lever on the dash down to the carburetor. There is a lever on the carburetor -- usually this has a hole in it where the end of the throttle cable hooks.
There should be a clamp in that vicinity to hold down the throttle cable housing to allow the cable inside to move back and forth without moving the cable housing,
May 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
50 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
