Question about Go Ped Toys
How to put a tire back on the axle of a goped grt46 and with spacers and washers
Simple, go to goped.com and find the Video section of the website there you will find a link to videos that will help.
1 put axle through frame
2 spacer and possibly a washer or two on the axle. Then wheel but make sure the sprocket on the wheel is lined up with the sprocket on the motor as you may need to add or take away a washer to get the alignment just right.
3 install wheel and put chain on the sprocket. Note, you may need to move the axle out of the way to get the chain on the sprocket and then wheel on the axle.
4 install spacer for the fender.
5 install fender
6 install and tighten axle.
Done
Posted on Mar 14, 2011
Rear tires
pop off the center caps from both rear tires with a flat head screwdriver, and then remove the push nut washers by bending them with a pliers and removing them (keep in mind this will ruin the existing push nuts and replacements will need to be purchase from ebay or somewhere similar) then slide the tire off of the axle and replace (do not remove the axle cause there are spacers inside the vehicle that will fall out of place)
Mar 18, 2014 | Peg Perego John Deere Turf Tractor
Change front tire
Remove brake caliper mounting screws from where they mount on the front forks. Slide caliper off brake disc and secure caliper
out of the way. Do not operate the front brake lever with the front wheel
removed or the caliper pistons may be forced out. Reseating the pistons requires disassembly of the caliper. On models with dual disc brakes, remove both calipers.
Remove axle nut lockwasher and flat washer from axle on left side of vehicle.
On right side of vehicle, loosen nut on pinch screw. Pull axle out of hub while supporting wheel.
Remove spacer and front wheel assembly.
Keep track of where each of the different size spacer went so you can put the back in the same order when reassembling.
For reinstall, you should get a manual as you will need to get torc specs. and other spacing and assemble instructions.
Sep 04, 2013 | Harley Davidson XL 1200 C Sportster Custom...
Hello, I have a 99 evo fatboy, with 3/4" axle. I want to make sure I got all the spacers and washers in the correct order when putting back on. Axle goes in on rotor side, with adjuster on first....
Sounds like you've got it together correctly. There is no washer between the brake caliper bracket and the swingarm. You can put the axle in from either direction. We usually put them in from the left side so that we no longer have to remove a muffler to remove the rear wheel. The nut is now on that side. Just make sure the wheel turns smoothly and the brakes work correctly before taking in out on the road. If you hear a chirping noise when you shift gears, your rear belt is too loose.
Good luck
Steve
Dec 17, 2010 | Harley Davidson FLSTF - FLSTFI Fat Boy...
How to disassemble the rear end in a 2000 gmc yukon and how to remove axles
Removal & Installation To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section
  2. Loosen the lug nuts on the wheel and tire assemblies but do not remove the lug nuts
  3. Raise and support the vehicle
  4. Remove or disconnect the following:
    • Wheel and tire assemblies
    • Axle lubricant into a suitable container
    • Rear driveshaft
    • Parking brake cable
    • Brake calipers
    • Shock absorbers from the axle brackets
    • Vent hose from the rear axle vent fitting
    • Nuts and the washers from the U-bolts
    • U-bolts, spring plates and spacers from the axle assembly
  5. Lower the axle assembly from the vehicle
To Install:
  1. Place the rear axle assembly under the vehicle
  2. Align the rear axle assembly with the springs then connect the spacers, spring plates and the U-bolts to the rear axle
  3. Raise the rear axle assembly into position
  4. Install or connect the following:
    • Washers and nuts to the U-bolts; Torque to: 59 lb-ft. (80 Nm) then, Torque to: 89 lb-ft. (120 Nm)
    • Vent hose to the rear axle vent fitting
    • Shock absorbers to the rear axle
    • Brake calipers (See: Brake Caliper)
    • Parking brake cable (See: Parking Brake Cable)
    • Rear driveshaft (See: Rear Driveshaft)
  5. Fill the rear axle with lubricant
  6. Bleed the brake system (See: Brake Bleeding)
  7. Install the wheel and tire assemblies
  8. Lower the vehicle to the ground
  9. Torque lug nuts as follows:
    • Single Wheel: Torque to: 140 lb-ft. (190 Nm)
    • Dual Wheel: Torque to: 175 lb-ft. (240 Nm)
  10. Road test the vehicle to check performance
Aug 03, 2010 | 2000 GMC Yukon XL
How do i get the back tire off my 1982 vf 750 sabre??
put bike on support stand or jack up rear wheel. remove small plastic cover on the left side swing arm and remove nut that anchors brake drum housing to the swing arm support. remove the rear brake linkage from the rear drum. remove the axle nut and slide out axle shaft from axle housing. Be careful to notice the position of the spacer and washers. the installation is the same as removal. be sure to re-adjust the rear brake linkage. If adjusted properly prior to removal it might help to mark the position of the nut on the linkage before removing.
Mar 30, 2010 | 1982 Honda VF 750 S
My left back tire of a 1991 Lincoln towncar fell off & i was trying to replace rear lugnuts studs
remove all brake components off of that side, pound out studs towards center of the car with a hammer. place the new studs through the back of the axle and then use washers that just fit over the studs for spacers, and put the lugnut on the stud and tighten until the new stud is seated on the back flange of the axle. remove the lugnut and repeat for the rest of the studs.
Mar 20, 2010 | 1991 Lincoln Town Car
Hello my dad has a 1100 sporster any way we took the front tire off and we should of marked how every thang goes back togeather we cant get the tire back on right anyone have any answers what side the...
If you have no idea where the spacers went ,then try them on any way ,You will know if they are in the right position as the disc break will only line up one way .and when you spin the wheel it should run fairly free .If it binds then its not right .
Mar 16, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
What is the sequence of putting spacers on rear
Not much on newer hogs but I'd guess if the spacers aren't the same length when you got the wheel on you'd see that the wheel isn't centered.Try again.Put the end thru the swing arm put on a spacer,push it thru the hub,put on the other spacer,push it thru swing arm put on washers and nut[loosely]and check the alaignment.Like I said I'm not much.
Mar 03, 2010 | 2005 Harley Davidson FXSTB - FXSTBI Night...
Toys Logo
242 people viewed this question
Top Go Ped Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Go Ped Toy Expert? Answer questions, earn points and help others
