Question about Sportsart 6300 Treadmill
I need an owner's manual for a Sportsart 6300 commercial exercise treadmill. I purchased a used one and it appears to be a terrific machine. I have mostly figured it out on my own, but a manual would still be much appreciated. Tried manualsonline.com with no luck. Many thanks! Jim McClanahan
    President:
  • 2,080 Answers
Click on the following link:
http://www.sportsartamerica.com/saf/support/technicalsupport/owners_manuals.asp
Select the 6300 Treadmill under COMMERCIAL PRODUCTS.
Save the file somewhere on your computer.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
Otherwise just unzip and open the file.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Posted on Mar 12, 2011
Testimonial: "Great service. just what i needed. many thanks! Jim McClanahan"
Sportsart 3000 treadmill problems
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Mar 25, 2013 | Sportsart Exercise & Fitness
SportsArt 6300 error display 04 -0015 help...
the power supply is receiving too low or higher currents.You must test this. Or you need to call the service tech. However try to RUN the s. calibration if you can. Otherwise reset the machine. and see the block diagrams attached.
God bless you
Dec 05, 2012 | Sportsart 6300 Treadmill
How to fit a new walk belt
proceed according and use common sense;God bless you
Jul 25, 2012 | Sportsart 6300 Treadmill
Fuse blows at the onset of starting the track
disconnect the motor from the motor control board under the motor hood ( follow the wires from the motor) and turn the machine on. If it lights up ok then the motor is blown.
Apr 13, 2012 | Sportsart 6300 Treadmill
Need an owners manual for A sports art 6300 TR 63
Go to SportsArt America.com click on support drop down and click on manuals click on owner's manuals scroll down treadmills and half way down you will find t6300 owner's manual
Sep 16, 2011 | Sportsart 6300 Treadmill
Hello. My sportsart give's error 7 ? I don't now what the problem is. Can you discribe the problem en the solution for this? Thanks Gert Jonker
When I turn on the machine it beeps and reads Error 7 on the screen. Do you have a support phone number for Australia
Feb 12, 2011 | Sportsart 6300 Treadmill
I need MOSFET transisitor NF43AT , where I can found it.
That Mosfet is probably porprietory from Sports Art , But I would check the bridge rectifier I've had quite a few short out and make it appear that the Mosfet is shorted. Any of the Parts houses would carry that component.
Mar 12, 2010 | Sportsart 6300 Treadmill
I have a sportsart 6300 that keeps blowing up Q2 and Q3
The bridge rectifier is shorted with gives Q1 and Q2 the appearance of being shorted and blowing the 15 amp ceramic fuse
Jul 12, 2009 | Sportsart 6300 Treadmill
What kind of wax do I need for my 6300 treadmills
You need to use a silicone Lubricant that may purchase @ gymparts.com it specify phenolic decks
Jun 26, 2009 | Sportsart 6300 Treadmill
Sportsart 6300 Treadmill Logo
475 people viewed this question
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven Brandon
Steven Brandon
Sportsmith LLC
Sportsmith LLC
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
