Question about Whirlpool AWM9000 Front Load Washer
The washe is flashing F-21. - Whirlpool AWM9000 Front Load Washer
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Posted on Mar 12, 2011
  • 1,940 Answers
  1. Disconnect the power to the washing machine.
  2. Remove the bottom front access panel (3 screws on bottom front lip)
  3. In the bottom middle, you will see the plastic filter access cap.
  4. Put a few towels down to catch the water that comes out, and unscrew the Drain filter cap.
  5. If you find socks, change, etc., clean it all out and put it back together.
  6. If it is clean already, check the drain pump impellers. They should freely move, if not clean the drain pump out.
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
F 21 problem
What is the complete model number of your unit?
Dec 03, 2012 | Washing Machines
F-21 on a Bosch 1400s- what does this mean
F21 Motor fault. Call customer service. (NOTE: if the motor brushes are worn, these can be replaced by a competent person).
May 20, 2012 | Washing Machines
The washer is flashing f 21
Check this video on how to solve the F 21 error code problem
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
\\\my washer flashes a F 21 and doesn't open. I washed my son's comforter the other day and the machine stopped and flashed a F 21 and would not open. when I finally kept pushing the unlock button a...
Your blanket probably caused an out of balance on the tub which caused the washer to stop in the middle of the cycle. The lock switch is a time delayed switch. Requires several minutes before it is activated to release. When washing single items you need to add another clothing item of approximately the same weight to create a balance during spin.
Dec 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HE 2plus problem
Hello, the F-21 blinking is an indication has a too long of a drain out condition, and what actually cause these is when the control call for the unit to drain and the water does not drain out in 8 minutes or less the unit will stop and flash F-21. So try checking the drain pump and pressure switch circuit.
Thanks
Jun 09, 2010 | Kenmore HE2 Plus Front Load Washer
Load stops and flashes F-21
F-21 is a code that indicates "long drain".Check the drain line for kinks or obstructions. Check the pump. Check eletrical connections at the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM9000 Front Load Washer Logo
222 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
