Question about Golden Technologies Companion II Travel Scooter
It is completely charges (electric scooter) lite and horn work ok scooter seems to be locked in place can't push it forward or backward doesn't move when i push the backward or forward lever
  • 11,800 Answers
I'm supposing that you haven't disengaged the brake with the handle on the rear, next to the right wheel - it should be in the up position.
If this is the case then i'm sorry to tell you but this is a bad defect that you cannot fix yourself: the controller board has failed and the motor is no longer powered, locking the wheels. You will have to contact the ones that sold it to you, they will have to completely replace it. Unfortunately there is only a one year warranty on it so you will have to pay for it - around $500.
Posted on Mar 12, 2011
How do I unlock my Pronto M 41 Scooter?
This may soundc crazy but try waving a magnet in front of the joy stick. It has been known to work.
Oct 07, 2016 | Electric Mobility Invacare Pronto M41...
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Can you help me try to figure out why my scooter will not move forward or backward? It is fully charged and the horn works.
I would get the batteries checked for power. Just because your charger shows fully charged quite often the batteries are low but enough power for lights or horn which does not take much power. i suspect bad batteries.
Apr 13, 2014 | Ctm Health & Beauty
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Mobility scooter - Electrics work, but won't go
hi, they are a nice scooter so let's get it working ,
First check that the freewheel lever is disengaged, in drive mode.
Do you hear a click when pressing the lever to go forward or backwards?
What can happen is the brake located on the side of the motor can seize,,,
Please keep me updated
Regards
Jan 04, 2013 | Electric Mobility Mobility Electric Power...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or...
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Oct 03, 2010 | Electric Mobility Mobility Electric Power...
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Golden Technologies Companion II Travel Scooter Logo
55 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
