Question about HP Office Equipment & Supplies
I HAVE PLACED MY BLACK CARTRIDGE IN THE COLOUR SLOT AND IT IS STUCK HOW CSN I GET IT OUT
  • 1,940 Answers
You may have damaged the Cartridge cradle already, but removing it may also damage the Cartridge cradle. First, inspect the cartridge to make sure there are no plastic clips, etc. blocking the passageway for removing the cartridge. It may take some force, but the cartridge should slide right out. Most HP printer cartridges are similar, if not the same size and shape, so it should come out with ease. You may need to use a flathead screwdriver, taking caution to not break the Cartridge cradle any more than it already may be.
Posted on Mar 12, 2011
Can i only put one ink cartridge in my lexmark x2480
If there is one slot that means you would be able to use only the color cartridge, But you will be able to print in any color you need.
May 03, 2013 | Lexmark 2480 Matrix Printer
I have message "Cartridge Error". I have established that the colour cartridge seems to be faulty. It is old and only replaced once because I do not actually need colour, use mainly black printing onl
Hi and welcome to fixya
You can print black pages with the color cartage. HOW ? just when you select the size of the paper A4 then ther is an option of colored printing or black if you have ink in the color cartage then it can be done that you can print black pages with that cartage
thanks hope that will be helpful
Dec 08, 2012 | HP Officejet 5610 All-In-One InkJet...
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
HP 4280 - new black refilled cartridge not recognised
hi steve... the solution to your problem is a costly one. the printer keeps in memory 2 cartidges for colour and 2 for black, when a third is placed in the printer the first one is deleted out of memory same for the colouredand same for the black... therefore you need 3 cartridges each to do the trick.
eg. if you want to use colour cartridge #2 then 1st place colour nuber 1 or 3, then turn it on let it reads, then open door and place in colour number 3 or 1 let it read, then take out and place in coulur number 2 and it will see it as new
Apr 03, 2009 | Office Equipment & Supplies
I have a Deskjet 6940 printer and ive bought a HP348 photo colour ink cartridge. it wont fit in the slot!? Does it go in the colour slot?
Your printer doesnt support HP348 cartridge.
HP 99 Photo is the cartridge meant for 6940 which wud go in the slot for black cartridge. and you can print approx 130 photos .
Mar 28, 2009 | HP Deskjet 6940 InkJet Printer
I changed the black ink cartridge as per instructions and the printer printed an alignment paper which i then placed in the printer for alignment but the alignment failed
the page should be absolutely new.and the scanner glass should be absolutely cleaned.and 1 main thing u replaced your black cartridge.but if your colour cartridge is empty it will not accept the allignment complete thing.it will show allignment failed as the particular colour is missing in your allignment sheet which is required to get the allignment complete.
Nov 23, 2008 | HP Office Equipment & Supplies
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
166 people viewed this question
Seeker5211
Seeker5211
