Question about Dell Latitude D610 Notebook
My d610 shows "media test failure, check cable" -
    Problem Solver:
  • 17 Answers
Check that the cable that looks like this http://networkcable-tester.com/wp-content/uploads/2011/02/rj-45-ethernet-cable.jpg Is plugged into the port located on the far left of the bottom picture http://i530.photobucket.com/albums/dd349/mobcomputers/d610allside500x500.jpg .
If it is, check to make sure there are lights that are blinking. If you do not see any blinking check to make sure that both ends of the cable are plugged in.
Posted on Mar 12, 2011
  • 55 Answers
The data cable that take the data from the hard drive or optical drive is damaged check the cable opening the compartment below or take it to technical service that is not an error that untrained personal can addreess.
    President:
  • 2,653 Answers
That message usually appears when the hard drive has crashed or if you're lucky you've got a cdrom or dvd in the computer and the boot order is messed up. 9 out of 10 though it means the hard drive has crashed though :(
Do you have any important files on the hard drive?
In IBM system X3550 M3 server pxe e61 media test failure check cable error is coming and when i mam trying to install OS Partition will not show. pls give me solution.
This sounds like you are asking two different questions. PXE booting would be the way you would begin installing or loading an operating system. "Media test failure" errors would indicate a lack of network connectivity on the network interface that you're trying to PXE boot from.
You go on to mention an OS partition not showing... So did you resolve the PXE media test failure issue?
Your question is unclear and unanswerable in it's current state. BE CLEAR, CONCISE AND SPECIFIC.
May 26, 2014 | IBM Computers & Internet
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
When power is on i get the PXE-E61 code on the screen "MEDIA TEST FAILURE ,CHECK CABLE" after that PXE-MOF code is show "EXISTING BROADCOM PXE ROM ..." my laptop is an acer aspire...
It is trying to boot from the network, basically from the internet cable that can be plugged in. If you enter the bios you can typically disable the PXE boot option so it won't show up again.
May 17, 2011 | Acer AS5741 CI3226 156 3GB320GB DVDR WLS...
When I turn it on, it makes a continuous sound for aprox 30 secs, then shows "PXE-E61 Media test failure". When working, it self-fills any empty fields with "n", not allowing any wrting...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 04, 2010 | Toshiba Satellite L505-S5966 Notebook
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Sep 18, 2009 | IBM NetVista PC Desktop
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
When I turned on my computer this morning it said "cannot find operating system" Further checking it had "F3E1000001 PXE - E61 Media Test failure check cable; PXE -M0F Exiting Intel Boot...
You hard drive is not being detected by the BIOS. The PCE-E61 is the attempt to boot from the network connection (Known as Pixie boot) and is a tool used in large networks.
Ensure your hard drive cables are properly connected/seated.
If reseating the cables doesn't change anything, try resetting the BIOS defaults, and see if the hard drive is detected.
If all the above fail, it is likely you have a hard drive failure.
Jun 17, 2008 | Toshiba Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Dell Latitude D610 Notebook Logo
188 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
