Question about Whirlpool Dryers
Dryer will not heat up and timer will not move
  • 55 Answers
I assume you have on the auto cycle. Try it on the timed dry cycle. If the timer runs, although it still may not heat, then you may need a cycle thermostat and thermal fuse also, possible a thermal limit. If the timer does not advance on the timed dry cycle them you need a timer. You can goto - http://www.searspartsdirect.com/partsdirect/index.action?pop=flush - for a parts breakdown and to buy parts. Good Luck
Posted on Mar 12, 2011
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Timer will run dryer but does not time
if the dryer has no heat the timer will not move on auto,when the heat shuts off the timer moves,when the heat comes on the timer stops,it will do this until clothes are dry
Oct 08, 2010 | Kenmore Dryers
Dryer will not turn off is it the timer? the dial does not move
do you have heat?when the dryer heats up the timer doesn't move,when the heat shuts off the timer moves,when the heat comes back on the timer stops,the timer will not move if there's no heat.if you have heat it could be the timer.also run the dryer when it's cold for 15 to 30 minutes and check to see if the flame is still liting,there's a little cover on the front panel that you can pop off to see the flame,there's a set of gas coils on top of the gas valve that when they fail they will stop working when they heat up,when the coils cool down they will let the gas through and the flame will lite again,common problem with gas dryers and most likely your problem.also when was the last time you cleaned out the dryer,you need to blow out the vent line if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the line,make sure the outside vent is clear so the air can blow through,next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year moreso with gas so you don't have a fire,also your clothes will dry on time and you'll have less problems with the dryer.let me know what you find.
Apr 18, 2010 | Kenmore 73952 Gas Dryer
My drum on my dryer rolls but there is no heat and my timer is not working...what could it be??
the timer will not move if there's no heat.when the dryer starts to heat and then shuts off then the timer will move when the heat starts again the timer stops.you need to send the model number is it gas or electric?you might need to clean out the dryer and popped the thermal fuse from the dryer running to hot or you have a bad heating element or ignitor,you need to get in there and start checking parts to see why you have no heat.
Apr 18, 2010 | Kenmore Dryers
Dryer will not heat, plus timer will not move
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 09, 2010 | Whirlpool LGV4634JQ Gas Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
Heats take long to dry and timer won't move
The timer not moving means that the timer has gone bad. The heating problem may have to do with the timer too. You can take off the vent tube of the dryer and make sure it is not restricted (from dryer to outside) If this is plugged it will also take longer to dry your clothes.
Feb 10, 2009 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
