Question about Curtis Audio Players & Recorders
Cd spins but for some reason it does not want to read the disc
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 92 Answers
Clean it with a cd cleaner a few times
Posted on Mar 16, 2011
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Panasonic Portable dvd/cd player model #DVD-LS90 The player turns on and tries to read the DVD. However, it no longer spins so the DVD cannot be read.
Two possibilities:
  • the laser eye (lens) is dirty, weak or defective. The unit no longer can sense that a disc is present and therefore will not initiate servo motor engagement. Pls try cleaning;
  • the spindle motor is weak or defective. This might be of additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Panasonic Televison & Video
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Player will not read cd . Cd will not spin
Without me seeing it, it usually cannot read the disc and is caused by a defective, or needs to be adjusted or cleaned, laser assembly as long as it is every cd put in it. It can also be the disc spinner motor. Either one of those is the most likely cause. :)
May 19, 2010 | Yamaha CDC-845 5-Disc CD Changer
The disks won't spin/read. It powers up and gets internet connected but it won't read disks. I have a 60gb and do not want to get rid of it. Whats wrong, where can I get it fixed, and how much should it...
THe lens of your PS3 if failing and thus the reason it won't read discs. You can call Sony andhave it fixed, it's free if warranty is still good and $159 for out of warranty repairs.
May 17, 2010 | Sony Playstation 3 (PS3) Console
CD-ROM won't spin up
When the CD drive doesn't detect a disc or can't read a optical disc, it stops spinning. Perhaps you need a new CD drive or Lens needs cleaning.
Sep 09, 2009 | Dell Dimension E310 PC Desktop
Stopped reading cd's
its means that your CD player cannot read data. actually the problem is in your lens. try to clean frist by cd cleaner disc with liguid and try. same problem change CD OPTICAL LENS.
Jun 07, 2009 | Audio Players & Recorders
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
77 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
