Question about Makita 12" Compound Miter Saw LS1220
I dropped my makita ls 1220 and put it out of square want to know if there are adustments to fix it thank you
  • 8,197 Answers
Page 20 of the manual on the link below will tell you how to square the saw.
http://www.makita.com/en-us/Assets/Output/DownloadFile.aspx?FileName=Products/LS1220/owners_manuals/LS1220.pdf
Posted on Mar 12, 2011
Promblem with Makita 1013 ajusting blade to cut square
Just found your problem, what you need to do it unplug tool and get a good square. Set the blade at 0deg. and then put the square on the left side of the blade to check it. If it is out of square you would need to loosen the fence bolts (13MM) and adjust the fence, snug bolts on the left side and move your square to the right and recheck and then snug the bolts there, I always recheck the fence to ensure it is square and not moved before tightening the bolts fully. If the head is out there are bolts on the pivot that need to be adjusted and again recheck. If you go to Makitausa.com you can download an owners manual with instructions on what to do. Let me know if you still have problems.
Jan 06, 2011 | Makita 10" Dual Slide Compound Miter Saw...
Switch and bateries
Makita makes two 12V Ni-Cad pod batteries: Battery 1222/2.0Ah (PN: 192598-2) and Battery 1220/1.3Ah (PN: 192681-5). Makita's universal charger (PN: DC1804) will charge any Ni-MH or Ni-Cad pod or stick battery from 7.2V to 18V.
Aug 18, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Electrical wiring for Makita ls 1221
Check the inside of the cover where the power cord goes into the motor.
May 03, 2010 | Makita 10" Miter Saw LS1030N
Ls 1013 squaring cut
Best way is to go to Makitatools.com and type in your model number for a manual with detailed instructions that you can download for the adjustments. If you still have problems let me know I work on them everyday. Good luck.
Sep 27, 2009 | Makita Saws
I'm trying to change the blade on a Makita compound saw - the LS 1220
I had the blade changed but it was going "in and out" in a rhythmic fashion and I couldn't figure out why. I finally realized I had installed it BACKWARDS - the teeth were facing the wrong way. I might have realized this sooner but I hadn't tried to cut anything - the noise and visual was so alarming that I just shut it off (fortunately).
Aug 26, 2009 | Makita Saws
Blade popping off front wheel
Is the axle tight? Has the tool been dropped to warp the frame? But a quick fix if everything else is OK is to loosen up the axle and put a THIN metal shim on the backside of the axle and then tightening it back down.
Jul 29, 2009 | Makita 2107F Portable Band Saw
Makita 12" Compound Miter Saw LS1220 Logo
236 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
