Question about Delta Faucet Delta 56613-SS Three-Function Wall-Mount Hand Shower, Stainless
The shower arm on Delta 56613 has gone floppy on the ball and won't stay put. Is there a way to fix it? This shower head has been used 10 times at most.
  • 68 Answers
SOURCE: low pressure on Delta 1400 series shower head
The Shower Valve is regulated to give only 2.2 gallons a minute. If you have the shower head off test how many seconds to get an approximiate gallon running in the middle hot/cold position. If longer than 30 seconds either the stem in the valve is clogged or the water lines to the valve are too small or kinked.
Phil
Posted on Dec 09, 2008
manhandy
  • 146 Answers
SOURCE: Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Posted on Jun 26, 2009
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
  • 129 Answers
SOURCE: I have a Delta 1400 single handle tub/shower valve
You might have to replace the tub spout, because the divirter is not closing all the way. A new one will stop water from getting by it.
Posted on Sep 30, 2009
  • 129 Answers
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Posted on Oct 05, 2009
Ok we'll I'm trying right now to unscrew my old ball end shower arm and cannot for the life of me get it to unscrew and can't understand why?? I'm not too sure how long it's been there but it won't even...
use multi grips and unscrew the shower arm from the wall and attach your new arm in its place
use use multi grips on the knurled section that holds the ball ( shower head ) on and fix your new shower head in its place finger tight
Jun 07, 2017 | Cars & Trucks
I installed a single lever shower unit when water is turned on i water out of spout and shower head . i took it a part all washers look good and doubled checked unit was put on right to water lines
You should also have a diverter in the spout. Just turn the old spout off and turn the diverter spout on. You lift the ball on top to use the shower.
Dec 05, 2012 | Delta & Single Handle Shower Faucet
Can't regulate a delta shower.
If you have the type that you turn the handle like a clock, you have to find that perfect spot. It can be 3/4 of the way around. If you have the ball type, single lever, the rubber seats and springs under the ball should be replaced. Cost...less than $10 for the kit to do yourself.
Dec 04, 2012 | Delta & Single Handle Shower Faucet
I have a delta in2ition shower head. The shower arm has a water outlet head that is screwed down onto it (the water outlet head is round like a ball and has a hole in the middle of it from which the water...
Take the gasket to your local hardware store and have them match it up.The answer is no, the gasket is not supposed to be split. It was probably tightened too much.
Jul 24, 2011 | Delta & Single Handle Shower Faucet
Delta Victorian 5-Spray Hand Shower has no
hello
of corse ... sir want to get thread tape befor trying to fix the head .
unscrew the head of the shower not the arm.
after unscrewing the head ,look at the back were the thred is, there will be a siff. thust clean out the sif, put thread tape on the head again and bobs your uncel hehe. if that dosent fix it let me know .
Jul 08, 2010 | Delta & Victorian 5 Spray Showerhead
Could i get a clear drawn instruction for putting the together the delta monitor 1800 series showerhead?The showerhead doesnt seem to fit on to the pivoting ball. Thankyou
My first instinct from your description is that the arm that comes out the wall to put shower head on has a rounded ball as a part of it with no threads on it. If so, it needs to be replaced with a standard shower arm with threads on both ends to acccomodate your new head.
May 19, 2010 | Delta RP28602-CB Replacement Ultimate...
The shower head was in place for over a year. Then when my daughter was taking a shower the whole ''T'' head flew off at her. I've tried to reinstall a couple of different times but it keeps flying off...
just replace your shower arm that is what the shower head is connected to make sure you use teflon tape around the threads on each end of the shower arm that should do the trick
Mar 07, 2010 | Culligan & Hand Held Filtered Showerhead
I have a delta brilliance showe head and lost the directions on how to install. can u help me ?
put a little pipe dope or teflon tape around the threads of the shower arm and screw it on while holding the shower arm firmly---hand tight usually is ample
Mar 07, 2010 | Delta & Single Handle Shower Faucet
Leaking shower faucet
I do believe that Delta guarantees their faucets for life. Go online to get the 800 number and call them, have the model number ready. They actually sent my girlfriend a replacement for her $300 kitchen faucet and also the guts to 2 bathroom faucets. They come with diagrams also. Of course I had to install them, but they stand behind their stuff.
Nov 20, 2009 | Delta & Single Handle Shower Faucet
Water leaks from the shower head. I have a delta
You may want to replace the ball or cartridge whichever the case may be. Also be sure to use Genuine Delta parts as they will hold up much better than the aftermarket parts. I hope this helps.
Oct 28, 2009 | Delta T13420 Chrome Classic Single Handle...
Delta Faucet Delta 56613-SS Three-Function Wall-Mount Hand Shower, Stainless Logo
Top Delta Faucet Home Experts
john h
bobalix
 John
John
Are you a Delta Faucet Home Expert? Answer questions, earn points and help others
