Question about Directed Electronics System Docking Station for Select Sirius Satellite Radio Receivers and Apple iPod - SOLOD1
No sound from my directed electronics sirius docking station solod1
Keeps coming up no antenna detected...changed antenna ...same problem
Sounds like it could be the dock itself, but could also be the radio. Do you have other docking stations to test it out in? If it works in one dock but not the other, we know its the dock that needs to be replaced. If it does the same thing in both docks it is probably the antenna connection in the receiver.
Jun 14, 2011 | Sirius ST5TK1 XM SIRIUS Radio Receiver...
When I connect the sirius radio to the docking station (sirius connect home kit) I can hear the sound for a few seconds then the docking process engages and I loose the sound. I have the tuner set to...
Hello, I am sorry about your issue. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-DS575 Receiver
No sound from Sirius Sportster SP-R2R satellite radio
Hello there !
I suggest you fix it don't through it yet ,I want you to change this chip .
sound IC( Amplifier ) it could be damaged or something is loose inside .
good luck
Dec 08, 2009 | Sirius Satellite Radio Audio Players &...
Stiletto 2 volume in car is lower than regular stations
Try increasing the volume on the stiletto itself.
Mar 27, 2009 | Sirius STILETTO 100 MP3 Player
Panasonic CQ-DF903U How do I hook up my Sirius Radio to it?
Sirius radio connects via a special dock. Sorry, but you're screwed with your XM unit...
Apr 05, 2008 | Panasonic CQ-DF903U CD Player
Audio stuck on high
You cannot adjust the volume when the stereo cord is plugged into the back of the dock. Instead, plug the stereo cord into the front headphone jack of the dock. You will be able to adjust the volume then.
Mar 11, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Live feed will not brodcast
From what I've read you might simply call Sirius or go on-line and re-initiate your subscription. Try it, it might work for you.
Apr 15, 2007 | Sirius Satellite Radio S50-TK1 Satellite...
Directed Electronics System Docking Station for Select Sirius Satellite Radio Receivers and Apple iPod - SOLOD1  Logo
27 people viewed this question
Top Directed Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Directed Audio Player and Recorder Expert? Answer questions, earn points and help others
