Question about Magic Chef MCD1110ST Microwave Oven
When I try to turn the microwave on, the timer counts down as if it is microwaving, but nothing is happening. If you push down on the door in just the right way, you can get it to microwave. So I therefore conclude that the microwaving is still working (as is the light, timer, etc.) but there is some small part that is broken. There is a brown plastic thing inside the space where the lower of the two hooks that project off the door goes when the door is closed. This brown plastic thing is loose and flappy, but I have never examined it before so I don't know if that is the way it always is.
    Guru:
  • 262 Answers
This is a door switch.
They are safety devices to not allow the microwave to operate if the door is open.
Here is a link to a video that will show you the way to check and get to the switches.
Note: the front grille section will most probably have two screws in the facing of the grille located maybe 6 inches in from either side.
Click on the link http://www.youtube.com/watch?v=jLPJoh3O9KA
Posted on Mar 12, 2011
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
All the lights and buttons on the front of my Frigidaire PLMBZ209GC work but the turn table does not turn and the fan does not run and it does not heat. It counts down and the cook light beside the timer...
Hello :
That problem could happen because of a bad door switch .
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 31, 2010 | Frigidaire Built-In Microwave
Sansui Microwave: Nothing Happens when you hit start
there is a safty door switch,if that switch is not making proper contact this thing happens.open the microwave look for safty switch and replace it or if you know how to open it then clean it and it should work
Aug 07, 2009 | Microwave Ovens
Timer counts down but nothing happens
one of three of your micro switches that monitor your door is bad. easy to fix. remove control panel and u will see the switches that the roll cam for your door hits.
Apr 20, 2009 | Dacor DMT2420SS Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Magic Chef MCD1110ST Microwave Oven Logo
54 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
