Question about Vacuums
I need a replacement stylus for my Proteam Rectro Classic Record player that i purchased in 2009
Machine was running, it quit and has not ran since. This happened last week. I did change out the switch thinking that may be the problem.
Proteam Pro Force 1500XP Bagged Upright Vacuum
Tom, the motor has probably burnt out, if you dismantle machine you could test motor directly to prove faulty or just replace machine.
Mar 31, 2016 | Proteam Pro Force 1500XP Bagged Upright...
On the Pro Team Alpine how do I replace the receptacle?
If the rivits need to come out You will need a drill and bit small enough but not too big and drill it out, u will need new rivits and a rivit gun u can find at local hardware store
Nov 24, 2014 | Pro-Team ProTeam Alpine CM DT100 HipStyle...
Brush wont move and its not the belt
If the belt is not broken, most likely the brush roller needs replacing. If the brush roller turns freely then it is likely the pulley on the motor that drives the belt.
Oct 03, 2014 | Proteam ProForce® 1500XP Bagged Vacuum
Proteam proforce 1500xp machine won't start?
Check the fuse or the or the wire, could be broken
Mar 28, 2013 | Proteam ProForce® 1500XP Bagged Vacuum
I will like to know the part # for the on-off swicth of Proteam 1500
The part number is 105147. It can be ordered here: http://www.monsterjanitorial.com/proteam/p198/Proteam_105147_-_Switch,_Handle/product_info.html?osCsid=en87jr2q4166a52t513qvc1fb7
I've include a link to the parts diagram for future reference.
http://www.monsterjanitorial.com/partsdiagrams/proteam/proteam_proforce_1500xp_parts.pdf
You can also buy the switch from your local Aerus Electrolux store. It's the same machine as the Ultralux upright. For the store nearest you, follow the below link.
http://www.aerushome.com/storelocator/
Mar 30, 2011 | Proteam ProForce® 1500XP Bagged Vacuum
Where can a purchase a replacement power cord?
Any vacuum repair shop should be able to order one for you.
Nov 21, 2010 | Proteam Cascade 12XP Bagged Upright Vacuum
Our Proteam ProForce 1500 is 1 year old. The vacuum works (****) in the hardwood floor setting on the switch. The beater works on the other setting but it won't **** and beat at the same time. What is...
It may be something to do with the actual switch on this unit.
I have a feeling it may have to do with the wiring on the switch itself, perhaps one of the wires have come off or burned on the contact.
Is it something you could fix? maybe, open up where the switch is on the back there and see what is going on. If it needs a connector that you dont have, solder works too.
good luck.
Nov 06, 2010 | Proteam ProForce 1500 Bagged Upright...
Proteam Pro force 1500xp Upright vacuum... When I switch to the carpet setting I have no suction power but the beater bar is turning. If I switch back to the floors setting, the suction is excellent. ...
Just undo the screws on the front part of the switch assembly, carefully check all the leads to the switch. Mine slide off all the time as the switch is poorly designed and subject to damage when the darn thing tips over (easily!!!) new switches are about 7.50 USD.
Nov 03, 2010 | Proteam ProForce® 1500XP Bagged Vacuum
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
Vacuums Logo
183 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
