Question about Honeywell 17000 Air Purifier
How to check my honeywell 17000 voltage? Im in Hong Kong with 220V here, but I ordered the honeywell 17000 from amazon.us I tried plugging it to a stepped down plug but it only gives out "buzz" voice...the fan does not move at all thanks for helping
Why is there delayed start & screeching?
The motor needs to be oiled. There are places to add oil on the ends of the motor. There may be a start capacitor that needs replaced too.
Jul 05, 2015 | Honeywell 17000 Air Purifier
My honeywell HFD-015C air purifier wont turn on
Hello, this is Ava with Think Crucial.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 31, 2014 | Honeywell 17000 Air Purifier
Honeywell 17000 Air Purifier manual
Please refer to the link below for the Honeywell 17000 online manual:
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/portable_hepa_air_cleaners_17000.html
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Feb 02, 2013 | Honeywell 17000 Air Purifier
WILL NOT START....NO POWER? BOUGHT AT SEAR JUNE OF 2010. HONEYWELL MODEL 17000
Make sure that the receptacle that it's plugged in to is still working. The circuit breaker for that outlet may have been tripped in your home's circuit breaker panel. Or there may be a loose wire or bad connection inside the outlet box. May not be air purifiers fault at all.
Mar 29, 2011 | Honeywell 17000 Air Purifier
I want to take the 17440 air purifier apart to see why it won't start.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 30, 2010 | Honeywell 17000 Air Purifier
My Honeywell no longer turns on. What could be the problem?
It can be power to the unit, power to the switch,relay or power to the blower.
You will need to remove to check the voltage and continuity with a multimeter to confirm on this failure.
Aug 23, 2010 | Honeywell 50250N Air Purifier
Instruction manual for Honeywell air purifier 17352
Please refer to the link below for the Honeywell model series 17000 online manual:
Honeywell 17000S Owner Manual
Ava B.
Jun 25, 2010 | Honeywell 17352 Quiet Care Programmable...
Honeywell air purifier, will not turn on, obviously getting power. but pushing the buttons on the control panel does not result in the machine turning on. This is the 17000. Can anyone help?
Does this unit have a 3 volt battery in the control panel like the 17005 model? The battery lasts appx 4-5 years then the unit doesnt seem to work any more once you change it. The unit must be left plugged in while you change the battery otherwise you lose your programing. If your not under warranty, UNPLUG it then pull out the filter, take out the 6 screws, separate the sides, and expose the fan. If the fan does not spin very easilly with no drag, the bearings are gummy; which is why nearly all small motors get replaced. The motor can be easilly disassembled, gummy grease washed off with rubbing alcohol and a cotton swab, and reoiled with synthetic oil. These units are designed to gum up and require replacement at approximately the same time the warranty expires. They would last almost indefinitely if oiled in their little oil ports occasionally (every couple of years). If your bearings are stiff, then a hidden safety device has tripped to avoid a fire, and if you are handy, you can replace the blown fuse if you can locate it on the circuit board, or the blown over temp device. If you have to pay some one to do this, it is cheaper to replace the whole machine in this throw away world.
Nov 25, 2009 | Honeywell 17000 Air Purifier
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Honeywell 17000 Air Purifier Logo
168 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
