My stereo wont come out of power protect.....I've done everything I've had to do in the past..... ie: unplugged it, unplugged the speakers and it still wont come out of it!!!!!!!
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 12, 2011
How to remove protect sign from JVC KDR-416
Sounds like you have a speaker wire shorted or touching. Pull stereo out of Dash But leave wiring harness plugged in. With stereo off unplug positive and negative of one channel or speaker then power on to see if it starts to work. If it still says protect shut back off wire that channel back up and go to the next Channel. As you do this one speaker output should be the culprit. If you go through all 4 and it still says protect then it may be a problem within the unit itself
Oct 01, 2016 | JVC Car Audio & Video
Why will my speaker stop playing and go into protection is there a reset bottom
The "Built-in overload-protection circuitry" is just doing its job...protecting the speaker from damage. Lets look at your system 1st. Is your power amp or powered mixer underpowered which requires you to turn the volume controls up past 1:00? Big systems play loud at moderate setting where-as small systems must be max'd out to reach those same levels. Pol-mount your speakers for better coverage as your ears are not attached to your shoes.
May 20, 2014 | Behringer B1520 Pro Eurolive 15" 2-Way...
Protect comes audio
Unplug the speakers from the stereo, then try and power it on. If your problem continues, check the internal fuses on the stereo.
Aug 03, 2013 | JVC HX-C6 Shelf System
Both of my tv's died yesterday. My apex wont turn on anymore an the panasonic has no picture. Whats wrong.
As an electrician, when someone loses more then 1 item of electronics in 1 day, its almost
always traceable to a nearby lightning strike, accompanied by a lack of surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360. Surge protection can
be provided by the consumer at the power strip (a good one with builtin protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house protection, or per-circuit protection at
the breaker box, where a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed), other than renters insurance or homeowners insurance.
If desperate, you could try replacing the entire power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Aug 15, 2011 | RCA F36450 36" TV
Hi, i cant turn on my kr-v5580 the mute light blink maybe 5 times and then it makes a clicking noise ( like when a 5 stereo cd change cd ) then it stays on standby i unpluged everything an replug...
But did you TRY it with everything (speakers) unplugged?
Make it standalone to determine the internal/external determination...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Jul 21, 2011 | Kenwood Audio Players & Recorders
On my kenwood kdc mp438u i tried everything it said to do but it keep saying protect
Could be a short circuit on your speaker output, try disconnecting all 4 speaker wires and then power up. Otherwise its the audio amplifier circuit that needs to be replaced ( audio IC )
Sep 27, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
My Stereo Is Always On Protect Can It Be Easily Fixed
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 27, 2009 | Sony Audio Players & Recorders
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
DUB2502 amp
you probably have the speakers set to where it ecxeeds the ohm load limits. its only 4 ohm stable when bridged and two ohm stable when ran using two channels. so either run the speakers at 8 ohms each parallel or just hook one speaker to eack channel. if you do not know what i am talking about then just email me at grandam88@hotmail.com and give me the speaker specifications.
Oct 07, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
24 people viewed this question
 Grubhead
Grubhead
