Question about Samsung Computers & Internet
There is no volume. i have run the diagnostic and still nothing
    Problem Solver:
  • 7 Answers
Check all the wiring, make sure it is correctly connected, then go to control panel then sound or volume and it will let you test the sound. Also make sure your headphones are not connected this will impede your sound. Turn on you volume control, take it off mute.
Posted on Mar 12, 2011
2002 ford escape starts but wont stay running unless the foot is kept on the pedal. took it to a shop and had a diagnostic test on it. It's saying there is nothing wrong. Mechanic said it must be
Computers rarely fail. The diagnostic would not show anything wrong unless a trouble code is set UNLESS the diagnostic used live data vieew. Most shops dont do that . So at what RPM does it not die? How many miles are on it? Ford uses something called an idle air speed motor. They are prone to fouling.
Mar 31, 2013 | 2006 Ford Escape
What does diagnostic lights mean in dell studio 1535? How do I understand what the problem is by looking at the flashing lights? For instance, what is the problem if mute and volume up lights are blinking...
I have seen questions about the diagnostic codes (volume/mute LEDs) on Dell Studio 1735 1737 laptops where the Mute and Volume up lights stay on while the Volume down Blinks. So far as I can tell, by searching the web, no one has posted the meaning of these lights.
Well here is a link to tell what the light codes mean. If your system has power but is not performing a POST just check if the mute, volume up, and volume down multimedia buttons are lit in a sequence indicating a system problem.
Here is the wesite to explain those POST failure codes.......
http://www.techmonsters.com/DellTraining/bin/Foundation2010/Portables_Foundation_2010/Studio/Studio_1737/1737/general_ts.htm
Dec 08, 2011 | Dell Computers & Internet
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
My volume is low and pressing the scroll buton doest do nothing is it sopost to
take the phone to a mobile service center and have them diagnostic the problems and fix them.
Jun 01, 2009 | LG Shine KE970 Cellular Phone
My built-in microphone is not working on my inspiron 1525. nothing is muted and when i look at the audio equipment installed there is nothing there. I tried to download the driver but it said there was an...
You can try the steps below and it should fix the problem.
A.Adjust the Audio Source Control Volume for the Microphone
1. Double-click the Volume icon in the system tray located in the bottom right side of the screen.
2. Click to uncheck any check marks in the boxes next to Mute to turn off muting for each volume control.
3. Click and drag each Volume Control slider to the top of the scale, if necessary.
4. Click Options and then click Properties.
5. Click to select the Recording radio button.
6. Click to check all the boxes listed under Show the following Volume controls:.
7. Verify the Mic Volume box is checked and click the OK button.
8. Click to uncheck the Mute box to turn off muting for the Mic Volume, if necessary.
9. Adjust the Mic Volume slider until it is near the top of the Volume Control scale.
10. Click Options and then click Exit to close the Volume Control window.
B. Test Sound Recording with the Dell Diagnostics
Follow the link below to run PSA
http://tinyurl.com/6f3lcd
1. Ensure the system is powered off.
2. Press and hold the Fn key while system is powered off and press the power button to power the system on.
3. Release both buttons in 5-10 seconds.
4. The PSA diagnostics sequence begins. Tests will be performed automatically.
5. A message will display “where the color bars displayed”. Press ‘Y’ to continue testing.
6. Make note of any alert tones or error messages and forward it to us.
7. When a prompt comes to run more memory tests, Press “NO”.
8. Another test starts and chooses option “TEST SYSTEM”.
9. Please select “CUSTOM TEST” from the options.
10. Please locate “Audio”, click on that, and find “quick test only” (right top corner). Start test, by clicking on the start test button.
11. Make note of any alert tones or error messages and forward it to us.
Download and Install the Latest Audio Driver
Uninstall the Audio Driver
1. Click Start and then click Control Panel.
3. In the Control Panel window, double-click the System icon.
4. If present, click the Hardware tab.
5. Click Device Manager.
6. Click the plus (+) sign next to the Sound, video and game controllers category.
7. Right-click the name of the driver you want to uninstall and then click Uninstall or Remove.
Download and Install the Most Current Audio Driver Available
1. Go to the below mentioned link.
http://tinyurl.com/3vlce4
2. Locate Audio and click (+) sign next to it.
3. Click the Audio driver that you want to select. You may have to specify an installation method or operating system type.
4. Click Download Now in the File Name section.
5. Click Save. Using the Save In: drop-down menu, select My Documents, then click Save.
6. Click Open when the download completes.
7. Click Continue.
8. Click OK.
9. Click Yes in the Folder does not exist. Do you want to create it? Window.
10. Click OK, and follow the onscreen instructions.
Test the Microphone Using Windows® Sound Recorder
Click Start, click Programs (or All Programs), click Accessories, click Multimedia (or Entertainment), and then click Sound Recorder.
Click Record, and speak into the microphone. You will see the green waveform react to your voice.
Click Stop.
To hear your recording, click the Play button and verify the volume level.
May 12, 2009 | Dell Inspiron 1525 Notebook
Volume Box wont go away
Try running the game in windowed mode. Open up the WoW game, go to Video, then check "Run in windowed mode" this will let it run like any other program. (You will still be able to see your task bar however it should remove the volume box)
May 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Iphone volume keeps appearing
have you tried restoring the phone or turning it off and back on?
Mar 29, 2009 | Apple iPhone 3G
Doesn't turn on, Mute and 2 volume lights constantly flashing
Your Pc motherboard is faulty, have a system engr look at it for possible reapirs." it won't boot ecept it is work on. Good luck
Feb 07, 2009 | Dell Computers & Internet
Installation Diagnostics Does Not Run Automatically? What to do?
this sounds like the driver is corrupted..go here, and get fresh drivers
Jun 14, 2008 | Brother MFC-620CN All-In-One InkJet...
Computers & Internet Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
