Question about Abit Fatal1ty FP-IN9 SLI Motherboard
When i click on my computer to show the drives.my hard drives show but my cd and dvd does not show. windows says that the drivers loaded but cant find the devices. so i shut down to reboot then i pressed the delete key to look at the setup screen. my cd/dvds shows them. then i had disconnected the drives and rebooted removed the drivers and shut down again. plugged the drives back in then booted up again. same thing again windows said it loaded the drivers but cant find the devices. so i think it has to be compoent failer. and if so i would like to find another motherboard to match the one i have.
  • Abit Master
  • 27,725 Answers
Click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone hope this helps don
Posted on Mar 12, 2011
  • 55 Answers
Your windows have a serious crash, I men sometimes virus, malware of just crashes makes those kind of failure, The best is if you already check for viruses is to reinstall your OS (windows) again.
    President:
  • 1,623 Answers
Have you tried changing the lead that is used to connect the drives. Also if you are connecting more than one cd or dvd then try connecting just one to see if they are detected . If they are detected on there own then you have not set the jumpers on the back and they are conflicting over who is master or who is slave. there is three settings on the jumper master slave and cable select
Hello! I had to reinstall windows xp, on my computer. Now when I tried to load my games back on, Some of the disk are not working. The green light comes on and I can hear it spinning, but the Icon never...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 19, 2011 | LG GDR-8162B Internal DVD Drive
Drive will not show up. It is showing up under devices
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Aug 08, 2011 | Glyph GT 050Q Hard Drive
Not detecting windows xp booting cd vista booting dvd detected but showing size 0 canot creat patition what io
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jun 29, 2011 | Fujitsu (MHT2040BH-50PK) (mht2040bh50pk)...
D: drive on my computer does not show up anymore. I boot up the computer and the letter does not appear under Computer. I put in a disk and the machine is connected for power, but I cannot load or write...
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 01, 2011 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
Installing DVD-RW LiteOn iHAs124-04 b AL0L with Windows 7 64bit but getting "Device driver software was not successfully installed." General Device Properties show:" Windows cannot load...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 26, 2011 | Lite On LiteOn IHAS124-04 Black 24X SATA...
My cd/dvd drive on my acer aspire 5810tg does not work since restarting my machine to factory settings. Please help
You may need to reinstall the drivers. Open your Control Panel, the double-click on the "Device Manager. In the Device Manager window, look for "DVD/CDROM Drives" (or similar) and click on the little box to the left to view your DVD/CD drive.
Right-click on the drive, and select "Properties." Another window will open, containing several tabs. Click on the "Driver" tab, then click on "Update Driver." You will be given the choice to have Windows "Search automatically" for the driver, or "Browse my computer.."
If you "Search automatically..." Windows will search the Internet for the mlost recent driver, and if it is able to locate one, ask you if you want to Install. Clicking on "Browse my computer" will cause Windows to search your hard drive for the correct driver.
As a last resort, if you received a CD/DVD with your Acer, and you can get a hold of an external CD/DVD drive to connect (via one of the USB ports) you can have Windows search the original software disk and load the driver from that.
Hope this helps :)
JB
Jan 03, 2011 | Acer (KV.16X04.007) DVD Drive
CANT FIND IT ON MY COMPUTER
have u insert it? check it at first in device manager then inform is it showing or nt?
Mar 24, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Windows unable to locate cd drive
you reformat your hard disk and install guienuine microsoft window xp your problem will be fix
Oct 26, 2009 | Computers & Internet
CD drive not working
Based on your indication the CD drive is clean, and you know the cables are attached to it, inside the computer. (Flat ribbon IDE interface cable, and 4-pin Molex connector power cable)
1.Go to Device Manager
Left-click on Start. Right-click on My Computer. Go down, and Left-click on Properties. Left-click on the Hardware tab. Go down, and Left-click on Device Manager.
Left-click on the + sign to the left of, DVD/CD-ROM drives.
Right-click right on the name of the CD drive.
(Example: Lite On DVDRW LH-20A1P.
eMachines Support indicates the T5212 has a DVD burner drive, and a CD drive. Right-click on the CD drive name))
In the drop down list, Left-click on Properties.
Left-click on the Driver tab
Go below, and Left-click on the Update Driver 'button'. Now go below, and Left-click on OK.
Close all windows, go back to your desktop screen.
Shut your computer down normally. (Start>Turn Off Computer>Shut Down)
Do Not Restart. We need a 'Hard Shut Down'.
Wait 1 minute, turn your computer on.
Still doesn't work?
Let's play hard ball.
2.Go back to Device Manager. Left-click on the + sign to the left of DVD/CD-ROM drives. Right-click on the name of the CD drive. Left-click on Properties. Left-click on the Driver tab.
This time go down, and Left-click on the Uninstall 'button'. Go below, and Left-click on OK
There will be a Microsoft 'squawk box' that comes up. "Warning you are about to uninstall this device"
Left-click on OK. (It IS okay!)
Close all windows. Shut down your computer normally. (Again, we need a 'Hard Shut Down'. To Restart a computer is known as a 'Soft Shut Down')
Wait 1 minute. Turn your computer on.
After Windows loads all the way, and all of your Start Menu programs have loaded, you should see a pop-up out of your system tray. (Bottom of Windows desktop screen)
"Found New Hardware", and perhaps another one, "Found XYZ CD drive". (XYZ = the CD drive name)
No still?
The driver for your CD drive, is located within the Windows XP operating system on your computer.
If your CD drive does not work now, I suggest it has failed.
Drives such as Optical drives, and Harddrives, are mechanical devices. Their 'Lifespan', is rated in so many hours of usage. Your CD drive may be at the end of it's 'Lifespan'.
Oct 04, 2009 | Sony VAIO PCV-RX462DS PC Desktop
GMA 4082n device driver not working properly code 39
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
Abit Fatal1ty FP-IN9 SLI Motherboard Logo
54 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
