My indoor unit is working but my compressior is not working. Help
  • 41 Answers
On most units the outside is fed from a seperat breacker or fuse look ther first dan
Posted on Aug 01, 2008
A/C Unit SAMSUNG -Outdoor unit model= MH080FXCA 4A was connected to 3 indoor units:
It's possible you have a bad data wire on one of the systems. Swap the data wire or both if two with a different wire. (1&4--2&3) whatever. Whatever you do inside obviously do outside. Might have extra resistamce that is throwing the error but will be fine for a ground wire.Or do one system at a time, being sure to change your dip switch settings until you figure out the problem unit. Good Luck!!
Apr 19, 2017 | Samsung Heating & Cooling
Why my Midea a/c 60,000 BTU showing PC error at the indoor unit?
Make sure your indoor blower is blowing, If not you have either a control problem or a bad blower motor.
Sep 17, 2014 | Midea Heating & Cooling
36VDC Split Air Conditioner indoor unit in a 240VAC country
Will not work. If you plug in a 120 volt appliance into a mains that is ordinarily 240 volts, you will destroy/burn up the unit. If you use a step down transformer - 240 to 120 you can then use the appliances - just make sure that it is a large transformer that can handle the large current (s) involved.
Apr 02, 2014 | LG Heating & Cooling
Why is Mr Slim MS-SGF24VC outdoor unit working when indoor unit off
Possibly a bad control board in the outdoor unit. Pull the disconnect outside to stop machine, wait 10 seconds and out back in. White mist was likely frost built up on indoor coil due to condenser running without the fan.
Jun 11, 2017 | Heating & Cooling
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
84 Mustang AC Problem
jumper the low pressure switch on the Acc. if the AC runs, check the charge on the A/C if the charge is correct. replace the LPS.
Aug 18, 2009 | 1984 Ford Mustang
I have a Westpoint SPG131HP. The remote control cannot switch the indoor unit on and no beep is made (remote controller is fine b'cause it works on other units). The a/cond works if switched on from indoor...
The receiver was tested on another indoor unit and it didn't work. Problem was therefore located. Replaced the 'eye' on the receiver in the indoor unit.
Jun 21, 2009 | Heating & Cooling
Honeywell Thermostat
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Dec 23, 2008 | Honeywell Electronic Programmable...
Engine Starting to get hot and A/C compressor isnt spinning
hi if the engine temp is normall check to see if theres a 12v supply at the commpressior when the ignition is on and the a/c is on as this operates the compressiors clutch if you mean the pulley that on the compressior is not turning the compressior is seized and the belt dragging causing the engine to overheat due to the extra load its trying to rotate yates210456
Aug 23, 2008 | 2006 Hyundai Elantra
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
