My simpson 7.5kg washing machine is leaking underneath and sometimes does not empty.
  • rakeshdiana Nov 15, 2008
    my simpson 7.5kg washing machine is leaking underneath and sometimes does not empty.
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
futureloginn
  • 734 Answers
SOURCE: leaking washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
  • 4 Answers
SOURCE: Simpson washing machine not turning on
check outlet with multimeter for 120 volts .If voltage found check cord for 120 volts .If cord has 120 volts turn on timer jumper lid switch . did this help?
Posted on May 30, 2009
  • 41 Answers
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Posted on Jul 11, 2009
  • 92 Answers
SOURCE: Whirlpool Ultimate care II washing machine leaking
if its leaking from the center probally the pump
Posted on Jan 15, 2010
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
Simpson washing machine problem have taken out stainless steel wash bowl and the plastic top/seal around it has water in it is that normal for that to happen
Yes. Some have water & some have sand in that ring. It is a balance ring to stop vibration when bowl spins. Do not empty it.
Jun 27, 2016 | Simpson Washing Machines
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
I need a schematic diagram for simpson riveria22p728-e washing machine
My oil light staying on and not getting oil to the valves. Is it my oil pump or where should I start?
Jan 04, 2013 | Simpson Washing Machines
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Nov 08, 2010 | Siemens Washing Machines
My washing machine was running and suddently flooded the room, masive leak somewhere. It is a Simpson Esprit 750 top loader, any suggestions?
probably a hole in the tub or one of the hoses. If you can flip the machine over and look underneath you will probably discover the source of the leak. If it's a hose, you can probably get a new one, but if it is the tub, you need a new machine, it isn't worth the time or effort to replace the tub :(
Joe
Aug 31, 2009 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
