Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
What grade of oil should I use in my 650 troy build 650 mower, How dI charge the battery?
4 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: after changing oil in troy built riding mower the
That is a safety feature with a lot of engines, there is a reset somewhere, call your Troy built dealer and ask him, I'm sure he will help. I will be a simple fix.
Posted on May 17, 2009
SOURCE: troy bilt zero turn
I have a zero turn Troy Built, It runs but the blades aren't engaging, I pull and push the pto button but nothing happens.
Posted on Aug 03, 2009
mowerman1857
  • 389 Answers
SOURCE: white smoke and oil spewing out of troy built
Check your oil level. If it is way over full, smell it to see if it smells like gasoline. If it does, you have a carburetor leaking gas into the engine crankcase. If you recently had the mower over on its side for blade changing or inspection, you have gotten oil up on top of the piston and it should burn off in a few minutes of running. Check your air filter to see if it is soaked with oil, replace it if it is.
Posted on Sep 19, 2009
I have a 2015 Troy Bilt Pivot S ZTR 54" mower. It was running fine when last used Sept '16, but now it womt start. It has fuel, battery shows a full charge & oil is full. This widow needs help!
Does the engine crank when you try to crank it? Or does it completely ignore you? What do you mean by it shows a full charge? Do you mean the battery?
Apr 18, 2017 | Troy Garden
How to check transaxle oil level on troy build riding mower
Most of these transmissions are sealed units requiring no user intervention.
May 04, 2015 | Troy Garden
What oil do I use for a briggs and stratton 650 series
Any good grade of SAE 30 will do fine unless on cold weather operation..then SAE 10-30 ..
May 22, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
What kind of oil does my mower takev 6.5 briggs stratton engine troy built
Most Briggs engines will be fine with a straight SAE 30 grade oil.
Feb 17, 2012 | Garden
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
My mower has been stored for about 6 years - I
Standard 87 octane should work fine. Try to run ones that are not an ethanol blend as they can damage fuel pumps..... regular 30 wt oil should work as well. If it has been stored for about six years, there may be issues with the carb and it might be good to take it and have it serviced first by a lawn mower technician.
Jun 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troybuilt/bronco wont start
IF YOU HAVE A NEW BATT IT COULD NEED THE VALVE LASH RE SET
Sep 19, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Troy bilt zero turn
Hi please check all the wiring connections as you must have disconected the power soarce feeding the key switch to the starter.
Start around the engine then the battery, check the seat switch , brake/ clutch pedal , & the mower deck switches .
One wire is just disconnected or the connection is broken so check all connections by unconecting & reconnecting them as it may even be a corroded wire that has been disturbed when being cleaned.
Oct 26, 2008 | Troy Garden
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
