Question about Toshiba Satellite L305D Notebook
I have hooked up an external monitor to my toshiba satellite l305d notebook. When i go onto screen resolution and detect it the external screen shows up, i just cant get a picture on it. It used to work, wondering if i can download a driver for it, whether the screen may be the issue (it works fine through hdmi for my ps3 but not the VGA with my laptop). i used to be able to connect the external monitor and it worked fine, now it just says there is no video signal detected
  • priceyrice Mar 12, 2011
    thanks for ur advice. Unfortuantly the problem is deeper than that. I can do this fine and set the input to either duplicate or extend my monitor, but either one, my monitor still doesnt show anything as says when i set it to vga there is no signal input
  • Toshiba Master
  • 1,583 Answers
The external monitor may require a manual selection of the input (VGA, HDMI, etc.). Find the menu button on the monitor and look for an input selection option. You probably already know you can switch between the laptop display and the external monitor by pressing Fn-F5.
In the worst case, you have a hardware failure - possibilities include a broken wire in the VGA cable (most probable, and easiest to repair), cracked connection in the VGA connector or bad VGA video buffer/switch chip in your computer, or bad video source switch in your monitor.
Posted on Mar 12, 2011
    thanks for ur advice. yeah i have checked my monitor is on the vga input, however the problem is deeper than that, if i set it to duplicate or extend my screen nothing shows up on my monitor screen still. Just says no VGA video input
    i think it must be one of ur worse case scenarios. My laptop gets very hot by the part where the VGA connection is, so worried something around there may have broken. I have tried another vga cable which doesnt work either. I will try another monitor and see if the problem lies with that, if not guess we can say the problem is 100% with the laptop
  • 55 Answers
There must be a Function key that makes your laptop to send video signal to the external monitor, if using Windows 7 use the WIN + P shortcut.
    thanks for ur advice, didnt know about that shortcut, however the problem is deeper than that, if i set it to duplicate or extend my screen nothing shows up on my monitor screen still. Just says no VGA video input
  • 64 Answers
Try searching google for your monitors model name and "driver"
My toshsiba l305d-s5881 screen is black and i can not see anything when i rebootthe system
try holding down your Fn (function) key then taping the F5 key (change monitor) on startup. also you can try to plug in an external monitor to see if you can change back to laptop monitor.
Sep 16, 2014 | Toshiba Satellite L305D-S5881 Notebook
My Toshiba satellite M35X-S149 shows the lights and can hear it running but there is no display on the computer monitor
Hi oysertails...
Try hooking your laptop up to an external monitor...if you can see the picture on the external monitor then your lcd screen may need replacement or the lcd inverter board.
Please take time to rate me
Sep 24, 2011 | Toshiba Satellite M35X-S149 Notebook
I have a satellite l305d-s5895, I broke the LCD so I can't see anything durning start up. When it broke i could see the colors of windows, first time I powered it on the the LCD would just flash then...
1) I would suggest you disconnect the video cable from the laptop (Motherboard) to the LCD screen, and the Inverter cables in the Display Assembly.
2) Then attach a VGA monitor to the VGA connector on the back of the laptop, so you can see what is going on.
(Laptop off, monitor off, attach the monitor)
I'm going to just assume damage to the LCD screen itself, and not possible damage to the entire laptop, since you just indicate a broken LCD screen.
If the laptop was closed during being damaged, the problem may lay deeper than just the LCD screen.
(For one example; If the laptop was closed, and damage occurred to the body of the laptop, the cooling fan assembly may be damaged, and the fan isn't spinning.
The Processor, and the GPU, need air to cool them. They operate within a certain specific temperature range.
Too hot and BIOS turns the Processor off. {No Processor operating, no computer)
If the LCD screen was damaged towards the bottom, damage may have occurred to the Inverter, also.
To disconnect the video cable from the motherboard:
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
Work on a table.
2) Observe Anti-Static Precautions
3) Follow Steps 1 through 7 on this page, {Page 1}
(You can click on the photos in the steps, one at a time, to enlarge them),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/remove-screen-replace-video-cable-1.htm
4) Follow Steps 8 through 14 on this page, {Page 2}
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/remove-screen-replace-video-cable-2.htm
Follow Step 15 on this page {Page 3},
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/remove-screen-replace-video-cable-3.htm
You have to remove the Keyboard Bezel, then the Keyboard, then the Top Cover.
(Palm Rest Cover actually. Top Cover is Toshiba's nomenclature), to access the video cable's connector on the motherboard.
You have to remove the Display Bezel to access the Inverter.
The video cable's connector on the motherboard, is shown more clearly in Step 20 on this page {Page 3},
For more clarity here is a link to a free Service manual, for the Satellite L305D series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down with your eyes to the second Satellite heading. The one that begins with Satellite A10.
Go to the second line in this 'paragraph', and left-click right on - L305D
This is a PDF file. (The computer you are using now has Adobe Reader on it, which uses PDF files)
After you click on the file name, (L305D) it may take up to 30 seconds for the first page to come up.
It may also take additional time for the file to fully download.
I would use the Zoom Out icon in top header of the PDF file, to reduce the view size to 100 percent.
( It's the Minus { - } symbol )
Go to Page 176. (4.12 Display Mask)
In the top header of the PDF file is the page number box. It is to the right of the Down Arrow.
You can use the Down Arrow to go to Page 176, or;
1) Left-click once in the page number box
2) Type 176
3) Press the Enter key
With the video cable disconnected from the motherboard, and the Inverter cables disconnected from it (Inverter), and the VGA monitor connected to the laptop;
Install the Battery, THEN plug in the AC adapter. Plug the AC adapter into power.
A) Turn the VGA monitor on. Let it warm up until graphics show.
B) Turn the laptop on.
If the graphics from the laptop is Not displayed automatically when the laptop turns on;
Press, and hold down on the Fn key, tap the F5 key.
There are three possible displays available;
1) The laptop's LCD screen only.
2) The laptop's LCD screen AND an external monitor. (VGA monitor)
3) The external monitor only. (VGA monitor)
Tap until ONLY the VGA monitor is on.
{VGA monitor. Looks like a small TV. It is a CRT.
You can also use an LCD flat screen if it has a VGA connection, and a VGA cable.
VGA connector on laptop. Believe it is on the Right to the very front.
Don't know as I do not have a Satellite L305D-S5985 Notebook PC in front of me, and the User Guide on Toshiba eSupport is unclear.
Doesn't show the sides, top, and bottom of the laptop.
This shows you what a VGA connector looks like more clearly,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Good graphics on external (VGA) monitor?
Shut the laptop down normally.
Remove all power.
Connect the cables to the Inverter again. (NOT the video cable)
Reinstall the Battery, and AC adapter.
(Caution: It is NOT a good idea to have the AC adapter plugged into power, when disconnecting, or connecting to the laptop. You could get a voltage spike, and fry the AC adapter, laptop, or both)
Turn the laptop on.
Still good graphics?
Suggest you replace the LCD screen.
When obtaining an LCD screen, check the LCD screen's manufacturer code on the back of the LCD screen. Match it up to what the replacement LCD screen website indicates is a match.
Has to be a compatible LCD screen. The Inverter, and LCD screen are a matched set. They are both matched to the laptop.
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~L305D-S5895/
It would be best to buy, and wear an ESD wrist strap. Connect it's alligator clip to a good ground source. For an example, I connect to an unpainted surface of the metal frame, of an empty desktop computer case.
Average cost of an ESD wrist strap is around $3 to $5.
Cheap insurance to keep from static shocking your laptop, and have an expensive paperweight.
Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
If a multi-compartment container is not available, substitute with a clean egg carton.
Label each egg holder.
Some screws look VERY similar to others. DO NOT mix them up.
(For one, a wrong screw could screw in halfway, then be stuck.
Won't go in any further, and if you try to take it out it may twist off.
Not to mention what a longer screw than needed, may do for damage in the wrong hole)
Post back in a Comment as to your findings. Also post any additional questions in a Comment.
Regards,
joecoolvette
Sep 04, 2011 | Toshiba Computers & Internet
My Satellite l305d-s5904 turns on but the screen won't. I let it charge and lights on the keyboard come on but the screen just wont come on. I had tested my mom's monitor in it some days before this...
If you checked with external monitor, the inverter board sits under the screen housing is more than likely the problem, failing that! the lamp inside the screen housing, either way a computer tech is recommended.
Dec 31, 2010 | Toshiba Satellite L305D-S5904 Laptop
Hello My Toshiba Satellite a75 s229 Notebook Screen is Black and Glass inside screen looks cracked. Laptop fell 3'' ft. off table onto carpeted floor. Laptop powers up fine and I can hear windows start up...
The way to find out if it's just the screen is to connect the laptop to an external monitor. Pay attention to the F keys when you connect the laptop. On most Toshibas, you'll see a small depiction on the F5 key of a laptop next to a monitor. You either have to press that key alone, or hold down the fn key and then press the F5 key and let go to transfer the signal to the external monitor.
If the external monitor shows up good and you can perform all other functions on your laptop while viewing the monitor, you need only replace the laptop LCD. If it does not display correctly, then you're into the next round of troubleshooting.
Hope it works as above.
Good Luck
Jul 29, 2010 | Toshiba Satellite A75-S229 Notebook
DIM BACKLIGHT TOSHIBA L305D-S5924 LAPTOP
There are also another reason , the Back light lamp might be damaged also!
May 11, 2010 | Toshiba Satellite L305D-S5895 Notebook
My screen on toshiba notebook only show blank screen. The screen is not dark but has light . If i hook an external monitor it show on external but not on the laptop. I have replaced LCD screen but still...
How about the LCD inverter? Did you replace the inverter? It is probably not the actual LCD but just the inverter that needs changing. Give it a go, they are inexpensive, try eBay.
Apr 01, 2010 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba satellite L305d-S5934 laptop and when i turn it on all i get is a black screen and sound from when its coming on but nothing shows on the screen how can i fix that
Look carefully at the screen, you should see some very faint images while its booting up. IF this is the case you need to replace the inverter.
Mar 13, 2010 | Toshiba Satellite L305D-S5934 Notebook
Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite L305D Notebook Logo
505 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
