Question about Can You Imagine Amazing String Thing With BuiltIn Black Light
My amazing string thing isn't working. when i turn it on the two spinny motor things wont even start, so the string won't move all cool and pretty. i tried different batteries and it didnt work...the motors still wont even start.
Why car isn't blowing cool air except while driving fast?
Are you saying the air coming out of the vents is not cold unless you are moving ? Or there is no air unless you are moving ?
And are you sure the radiator fan is running with the ac on ? Can you feel air being pulled thru the condenser ? What are the gauge readings with the ac on and the engine at idle ?
May 18, 2013 | 2003 Mitsubishi Eclipse Coupe
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
Nov 12, 2012 | Cars & Trucks
Coolant fan isnt working on my 93 cavalier rs
You need to get a 12v test light for this sort of thing,otherwise you will waste a lot of money replacing good parts.If you already replaced the motor,the next logical thing to try would be the relay.(you can swap the cooling fan relay with one of the others in the relay center instead of buying another-just make sure you mark it before you move it).Try trading it with the fuel pump relay.If the relay is defective,the car won't start.If it isn't the relay,the relay socket is an excellent place to test everything in the circuit with the test light.
Jun 13, 2012 | Cars & Trucks
My air compressor just stopped working completely,has power to it and can turn the fan so its not seized but was gonna start by checking the reset relay and what appears to be a capaciter. just looking for...
The first thing to check is the thermal protector (circuit breaker). It is a small black button mounted on the housing on the back side of the pump motor. The unit will have to cool down before the button will reset. Usuall causes for the thermal protector to pop are: running the compressor on an extension cord, running the compressor on power lines or circuits that can't carry enough amps to run the motor, or little or no oil in the compressor causing excessive friction and heat buildup. If the thermal protector isn't tripped the next thing to check is the pressure switch. If the springs inside are broke or damaged they won't trip the switch to turn the compressor on. If the capacitor(s) are bad the motor will hum and/or try to turn but not have the power to start spinning.
Apr 27, 2011 | Hitachi EC119SA Twin-Stack Air Compressor...
Whirlpool dishwasher spinny thing is rattling
Hi, I suggest u to check these :
  1. Check the spray arm for damage and obstructions
  2. Check the inlet filter screens
  3. Test the water inlet valve
  4. Check the motor and mounts
  5. Check the fan motor and blade
  6. Check the drain for obstructions
Apr 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
WHIRLPOOL ELECTRIC WASHER STOPPED WORKING MIDWASH BC OF OVERLOAD?
My wife did the same thing,trying to do all the laundry at one time.Even if it says high load compasity it will only handle so much.sounds like you killed your motor.Hope this helped.
For more help go to live chat.
lenwest
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Fridge not cooling
Hello.
The first thing you need to do is take out the bottom drawer in the freezer and look into the slots in the back panel. Make sure that you can see silver coils, and not a bunch of frost. If there is, then you need a new defrost timer, defrost heater, or defrost terminator.
If all looks ok then make sure the fan in the freezer is running. (You may have to push the door switch if yours has one.) If the freezer fan isn’t blowing however, the freezer will be warm at the top and cool at the bottom, and you fresh food compartment will be warm.
Another thing to make sure is that the light it turning off when the door is closed. Again you would have to push on the door switch. I was amazed to learn when I first started this line of work, that even a little light bulb can make enough heat to cause a problem.
These are the most common issues.
Let me know if everything looks ok and I will go over some other things, as the list of things that can go wrong with a refrigerator is fairly long.
Dec 07, 2008 | Refrigerators
Freezer is not getting cool
Hello.
If this checks out ok, make sure that the coils underneath are clean and the fan is also turning (underneath the unit).
Dec 07, 2008 | Kenmore 53642 / 53644 Side by Side...
ELECTRONIC TEMPERATURE GADGE FLASHING AND BEEPING FRIDGE NOT COOLING
Hello.
Let me know if everything looks ok and I will go over some other things.
Dec 05, 2008 | Refrigerators
Can You Imagine Amazing String Thing With BuiltIn Black Light Logo
187 people viewed this question
Top Can You Imagine Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Can You Imagine Toy Expert? Answer questions, earn points and help others
