What is the normal cost to fix the flexplate - Computers & Internet
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
Roughly around $40-$75
Posted on Mar 12, 2011
What should the cost estimate be to replace the flexplate on a 2009 dodge ram 1500 4wd 5.7 hemi?
Not considering the costs of parts themselves, the labor to remove and replace the transmission, torque converter and flexplate runs estimates at approximately 4.5 hours. If you have a skid plate and dual exhaust, add another .5 hour. At rates of approximately $80-100 USD per hour of labor, you are looking at $360.00-$500.00 labor, plus the cost of parts and fluids.
Nov 02, 2016 | 2009 Dodge Ram 1500
Got a 95 mitsubishi galant 4 cil starter/flywheel noise
If this noise is really loud you will need to replace the flywheel or flexplate (if automatic transmission it is called a flexplate) and the starter, both of the gears that drive the engine rotation during start up are damaged. This damage is likely due to a bent or cracked flexplate if it is a auto transmission or a defective starter engagement drive, this causes the starter motor gear to not fully engage the flywheel gear teeth and causes damage, the damaged death cause the loud noise you here when you start the car. No matter the cause of this there is only one fix, a new flywheel or flexplate and a new starter.
Nov 09, 2011 | 1995 Mitsubishi Galant
Grinding noise when trying to start 04 Taurus about once per 40-50 starts. had starter replaced and now grinding is worse. once per 10 starts. starts on third try.
It sounds like the gap between the starter gear and flexplate is growing. The ring gear may be worn out in spots causing the starter not to engage the (shortened) teeth of the flexplate. Or the starter is shimmed too far from the flywheel ( less likely ).
The flexplate problem will require the removal of the transmission to repair.
http://www.carpartsdiscount.com/auto/parts/2004/ford/taurus/flywheel_flexplate/flexplate.html?3593=247290
The part itself is not that expensive, however, the labor to replace will bite you
Sep 20, 2011 | 2004 Ford Taurus
When i turn the key to start, I can hear the starter spinning but its not cranking the engine... i was told its the flywheel.. is there any other way to get the car cranked up or do i need it to be towed...
It is not actually the fly wheel but the ring gear that is shrunk onto the flywheel that is worn. If you can manually turn the engine about 30 degrees, the starter may take on an unworn portion of the ring gear (if the vehicle is a manual a push start will work). Once started it should be taken to get fixed because the chances of the engine stopping at the worn section of the gear again are about 75% sure.
May 22, 2011 | 1990 Oldsmobile Eighty Eight
Flywheel/flexplate broke on 1998 Isuzu Rodeo, need diagram.
You will have to remove transmission. to get to the bolts.
Feb 03, 2010 | 1998 Isuzu Rodeo
Starter bangig on flywheel what could cause this
Your starter drive mechansm drive teeth will be hitting the flywheel or flexplate's teeth. In any event, change it immediately as you do not want to have to change the flyweel (flexplate) as well because it's teeth may be ground down - which is not good and will be expensive to fix. hope this helps you ,Rick
Apr 18, 2009 | Hyundai Elantra Cars & Trucks
Starter or flexplate? 2001 Mustang
absolutely a known issue...cracked flexplate...pull starter and inspect flexplate very carefully for cracks before installing new starter and thinking its a done deal
Nov 06, 2008 | 2001 Ford Mustang
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
