I need to replace the heating element for a ge spacemaker dryer model #wsm27tdawww. it appears the drum has to come out first...any idea how to do this would be appreciated
rickzilla
  • 706 Answers
SOURCE: Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Posted on Jul 25, 2008
barkencoa
  • 3463 Answers
SOURCE: No heat on Indesit IS60V tumble dryer
The heater and stats are located at the rear of the m/c behind a removable panel.
you need a meter to test them, more likely to be a stat problem, but again you must test them for continuity.
Plz leave feed back for my solution.
Thanks.
Posted on Dec 14, 2008
Krazytech
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
  • 8 Answers
SOURCE: GE spacemaker dryer won't start
Have you tried keepin the dryer door open, depressing the safety switch which enables the dryer to work when it is closed, and then turn on the dryer to see if it turns at all? Sometimes its the smallest things that cause these problems. That switch that gets pressed when the door closes, sometimes malfunctions. Sometimes the door of the dryer gets out of whack and doesnt really make contact with the switch enough to trigger the flow of electricity.
Posted on Jan 13, 2009
dmftrucker
  • 1922 Answers
SOURCE: My GE Spacemaker Dryer Model WSM 2700 DA no longer
either the heating element, hi-limit switch, thermal fuse (on some), cycling switch,or a burned neutral power wire in the unit, first, make sure you have 240 volts input power
Posted on Oct 22, 2009
How to install a heating element in the GE wall mount dryer
GE Dryer design (Most or almost)....
Heating element access is from the front.
1. Remove the Front Door
2. Remove the belt.
3. Remove the Drum.
You see the heating element. Very simple design
Apr 06, 2015 | GE Dryers
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
Dryer runs but does not heat
If the dryer is electric, you most likely have one of two issues going on...
1. An electric dryer uses 240VAC to operate. That's actually two 120 volt circuits wired into the dryer. One circuit runs the drum motor and controls while the other is dedicated to running the heating element. Check both legs of this circuit for blown fuses, etc.
2. The heating element may be worn out. You can check continuity of the element to see if it has an open circuit inside.
If the dryer is gas, there are a number of possibilities... post again if that's the case.
Good luck.
Jan 18, 2011 | GE Spacemaker Washer and Dryer Electric...
Dryer runs but does not get hot and dry
It runs since the motor is still working and turning the drum. No heat since the heater element is broken so no heat got produced to dry clothes. Replace the heater element to correct the problem. Good luck
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My GE Spacemaker Dryer Model WSM 2700 DA no longer heats up. HOw difficult is it to change the heater element or is that the problem? P.S. I have cleaned all the vents out with very little material found.
Oct 22, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryer doesn't heat up
Take the back off the dryer and then take the heating element out and look for the coil wire to have a break in it. I have replaced serveral heating elements.
Sep 03, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Can you convert a 220 dryer element to a 120 ellement
no that machine is wired for a 220v. has 220v components in it. no way to change that sorry
Feb 23, 2009 | GE Spacemaker Washer and Dryer Electric...
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replaced dryer belt dryer was heating now isn't
There could be 2 problems coming into play here.
1. Check to make sure there is no blockage in the vent piping. If the vent is blocked and the air cannot discharge from the dryer, the heating element will overheat and the overtemp thermostat will turn the heating element off.  (By the way, Blocked vent is usually the No. 1 Culprit in problems like this.)
2. Check the heating element and make sure that the heating coils are all intact. An open or shorted heating coil will cause the same symptom.
Dec 14, 2008 | Dryers
Ge spacemaker washer and dry stackable.
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
