Question about Dynex 32 in. LCD Flat-Panel HDTV
How do you turn on closed captioning? - Dynex 32 in. LCD Flat-Panel HDTV
    Problem Solver:
  • 10 Answers
Using your remote:
1. Press the MENU button to open up the menu.
2. Press left or right until you reach the SETUP sub-menu.
3. Press UP or DOWN until you reach the CLOSED CAPTION option.
4. Press ENTER or RIGHT.
5. Press UP or DOWN until you reach the CC MODE option.
6. Press left or right to select ON
Hope this helps !
Posted on Mar 12, 2011
4 Suggested Answers
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
  • 4 Answers
SOURCE: cant turn off closed captioning
I have a PME-42S6 on Ebay that has a turning on problem it is a complete unit and work good if you can get it to turn on
Ebay # 120362175465
bid on it and pick it up and there is your remote control
Bob
678-333-6746
Posted on Jan 12, 2009
hulk917
  • 247 Answers
SOURCE: cannot turn closed captioning off.
Sounds like the CC data is coming from your cable service. I would check your cable box options and turn CC of there as well. what company are you with as far as cable ? also what model cable box do you have?
Posted on Sep 05, 2011
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
How do I turn off closed caption?
Hello
From the main menu, surf though and enter the closed caption window. Here you can see options for Analogue closed caption, Digital; closed caption and Caption style to select. Here select "OFF" for both analogue closed caption and digital closed caption option.OK.
Refer to your TVs user manual. If you haven't its user manual, inform me though Fixya. Send your email ID too. OK.
Feb 14, 2011 | Hannspree XV32 32 in. LCD Television
How to turn closed caption off?
If the cc button on your Sharp remote control isn't turning them off then the captions may be coming from your cable box. The hidden menu to access closed captioning on the cable box is usually found by turning it off and then (yes I did say turn the cable box off) then press the menu button on the front of it immediately after turning it off. Then you navigate down to captions and disable them. When you turn the cable box back on the captions should no longer be there.
Feb 01, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
Jan 30, 2009 | Televison & Video
A black box sometimes appears on my tv screen. can you tell me if this is from having the closed caption butten on and why it happens?
Yes, if the closed caption mode is turned on in 'text mode' the set will display a black box even when no closed caption text is available. the normal closed caption mode is cc1. try turning closed caption to cc1 or off. tech7
Jan 04, 2009 | Televison & Video
Closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
Nov 27, 2008 | Computers & Internet
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Dec 08, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Dynex 32 in. LCD Flat-Panel HDTV Logo
234 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
