Question about Dryers
I need a wiring diagram for the heating element on the Kenmore Dryer 110.86950100.
  • 55 Answers
You should find yours inside the control panel. If your is lost for some reason you could try manualsonline.com or allrepairmanuals.com
Good Luck
Posted on Mar 12, 2011
catriver
  • 878 Answers
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Posted on Dec 09, 2007
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 1028 Answers
SOURCE: Kenmore Dryer Model 110 Heating Element & Thermostat
believe that model has a relay under console..pull console end caps off remove screw on each end roll console back..if your model has an electronic bd it also has a heat relay it will be the one with 2 large red wires.. a quick ck would be to unplug power remove the red wires and tape bear ends together pug back up turn on dryer if it heats unplug and exchange the 2 relays the one with the blue wires is the motor relay and is same as heat relay try again if motor fails to start bad relay if motor starts bad control bd
Posted on Aug 10, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The manufacturer normally places a wiring diagram inside the operator console. Remove the back panel and there should be a diagram taped inside. Some of these diagrams will show two circuits. One is for a gas dryer, and one is for an electric dryer. Make sure you reference the correct one. I hope this helps you. If you need further assistance please let me know.
Posted on Aug 15, 2008
I found the solution to be very informative and helpful. However, I checked the resistance of the heater element and it is about 10 ohms, and is not open. The TCO resistance is about zero. What about the thermostat? No values were given to check it for, but I did check it's resistance and it was also close to zero. The thermostat sort or "rattles" when I shake it; is that normal?
I pulled the heater element out and looked at it, and can see no visible damage. Also checked the air outlet and hose - no blockage in the hose and the air output at the dryer seems fine.
What else could be causing the dryer to not heat. Have checked at all cycles and temperature settings (low, medium and high)?
Posted on Sep 16, 2008
Need diagram of kenmore oasis HE
Do you have a wiring diagram for the heating element for a kenmore oasis dryer
Mar 27, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I need to change the heating element on my dryer. how do I do this?
The exact process will depend on the model of dryer. I would suggest starting by looking at the assembly diagram for the dryer. You posted the question in the Kenmore section, so assuming that it is correct, you can get these diagrams from the Sears website. You can also order a new heating element there.
Sep 16, 2010 | Kenmore Dryers
We replaced the heating element, but don't know which wires go where to reconnect
Should be color coded Reds and black wires are hot greens are ground writes are nutural. Google your heating element wireing diagram
Sep 05, 2010 | Kenmore 62622 Electric Dryer
Kenmore dryer not heating during cycle, what do I do?
You'll need to check the thermostats and heating element. The dryer has like two or three thermostats: two that operate the heating element, and one that burns out like a fuse if it gets too hot. Pick up a electric multimeter. I got mine at wal-mart for $5. Put it on the resistance (greek letter omega or upside down horseshoe symbol). 1X or 10X or anything doesn't matter. When you touch the probes together the needle should jump, indicating that there's very low resistance there because the probes don't resist electricity flowing them. You can use this to test the components. Unplug the dryer for God's sake, and then try to take off the back panel. If you don't see a way you can probably "pop" the top of the dryer by prying it up with a putty knife in the seam between the sides and top of the dryer. Now remove the back, and find the heating element assembly, probably on the lower right. There will be two or three wires connected to the element assembly. Two 220v wires(probably red) will supply power to the element and one control wire(probably yellow) send feedback to the controller. Check the resistance of the heating element and each of the thermostats by putting the probes on the wires on each "side" of it and check the resistance. If something has a very high resistance on the high voltage wires, it's probably defunct and needs to be replaced. The yellow or control wire might have a resistor on it that your meter would read as bad, but you're only concerned with the high voltage supply wires. Note that the wiring diagram will probably be hidden somewhere inside the dryer when you open it up. If all the parts in the element assembly check out ok follow the wire connected from the element to the motor and check the resistance of the resistors and stuff on the diagram. Note that is a resistor have a value like 10k(10,000 ohms) you may have your meter set too low for the needle to actually read it. That's what the 1X, 10X multiplier settings are for if your meter has them. Other problems could be a loose wire, dirty moisture sensor inside the drum, defective controller, or defective switches.
Oct 23, 2009 | Kenmore Dryers
My kenmore series 80 electric dryer does not heat. I am replacing the TCO, but it does not appear to be hooked up. There are red wires going directly into the heating element, but the TCO lead is...
Yes, hook it up, but before you do that Vacuumn every piece of lint out of the cabinet. Also check TCO and check the thermostats for continuity. They should all read zero ohms.If one of them is open, replace it.
Also use your ohmmeter to check the heating element, It should not show an open condition.
Jul 29, 2009 | Kenmore 63942 Dryer
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Therostat kenmore dryer
It is kinda hard to mess up because the heating element terminals are larger than the limit terminals. The 2 purple wires go to the fuse.
They have smaller terminals.
Nov 05, 2008 | Kenmore 659 Electric Dryer
I NEED OWNERS MANUAL TO KENMORE DRYER
thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Mar 27, 2008 | Kenmore 63942 Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
