Question about Dewalt DW745 Heavy Duty 10 Inch Compact Job Site Table Saw With 16 Inch Max Rip Capacity
I have a site table saw TMN250TS it will omly run for 3or4 seconds the it switches off
My husband lost the safety key for our Hitachi Table Saw Model Number C10FR. This saw is discontinued and the customer service department at Hitachi will not return phone calls or E mails. Can anyone...
I found Hitachi customer service to be quite helpful in replacing my safety switch for my C10RA2 table saw. My C10RA2 has a fixed metal stand, not the folding stand, and the part number for the red safety switch or key is 531-992R, while the switch itself is part number 314-459. If you have the folding stand the part number for the switch is 321-620 and the safety key is 321-621. Hitachi customer service in US: 1-800-706-7337. I am going to buy two or three! Almost lost a table saw over a cheap plastic part.
Dec 27, 2010 | Hitachi C10FR 10" Job-Site Table Saw 15...
I need an instruction manual for a Craftsman 10 inch table saw model nmbr 315.228110
A pdf OM can be found at this link.
http://www.managemylife.com/mmh/owner_manuals/13651/CRAFTSMAN-Saw-Table-L0060173?brand_name_search=315228110+CRAFTSMAN
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 31, 2010 | Craftsman Saws
Does not turn on. The wood was at an angle and jammed when it quit working
Hello. I recommend that you check your circuit breaker or fuse which is in the house panel and feeds the outlet that your saw is plugged into.
I believe that you will find that you solution is to reset the breaker or change the fuse.
Nov 28, 2009 | Craftsman 10" Table Saw
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Jan 07, 2009 | Makita 2703 10" Table Saw, Electric Brake
Table saw Types
Portable table saws perform many of the functions of larger stationary table saws but have a decided advantage in their mobility. High mobility makes them the perfect choice for framing and deck building. They're also a good choice for small shops with limited space. Stationary saws added power enables the saw to run knives and cutters designed to mill and remove large amounts of stock and usually accept more accessories than portable saws.
Aug 27, 2008 | Dewalt DW745 10" Compact Job Site Table...
Dewalt DW745 Heavy Duty 10 Inch Compact Job Site Table Saw With 16 Inch Max Rip Capacity Logo
236 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
