Question about Sony KV-27S42 27" TV
KV27S42 problem my email is kevinkcam AT msn DOT com. KV27S42 Problem. I have no picture and 2 flashed of the red light at 3 second intervals. I powered it on using the Ke combination DISPLAY | 5 | VOL UP | POWER It will stay on but with no picture and the blinking code. What is that code? Thanks, Kevin
  • kevinkcam Aug 01, 2008
    Dan,
    The number is C5426 with a smaller OL4 elsewhere on the transistor.
    It does not have any discoloration or is mot misshapen although that heatsink is cold to the tough.
    What is the next most common failure after this?
    Thanks for your time.
    Kevin
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Hi Dan, my Sony doesn't blink or doing anything when I plug it to the wall, I remove the C5426 which I think it is 2SC5426. What is the number should I get when I use a ohm meter to measure either leg? When the transistor was on the board, I got about 69 volts from most of the ground and about 60 volts from some of the positive component. What do you think?
Posted on Oct 21, 2008
  • 4,234 Answers
The 2 blinks is an indication of overcurrent. That translates into a short somwhere inside the set. since you can get sound but no picture, that suggests that the problem is in the high voltage section. The most common failure there is the Horizontal Output Transistor. This is a 3 legged part attached to a heatsink close to the flyback transformer (part with large red wire coming out the top). That part should be marked C5438 or something similar. Post the marking here and I'll give you the complete part number.
Dan
Posted on Aug 01, 2008
  • ABRsvcs Aug 01, 2008
    You won't see the problem. If you have an ohmmeter, with the transistor removed, measure between the center leg and either outer leg. I suspect that you will read zero(0). If so, replace it. The full part number is 2SC5426.
    Dan
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Ink lights are not on error UO43
Perhaps one of the ink tanks is not snapped in properly. The cartridge lamps on this model glow red when they are properly seated/installed.
These little red lamps also flash codes:
Slow flash (approx. 3 second intervals) - ink low
Quick flash (every second) - ink cartridge empty
Dec 26, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Flm-3201
I would replace the control box assembly that is the most common issue with those TVs
May 22, 2008 | Televison & Video
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
Sony KV-27S42 27" TV Logo
420 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
