Question about Coffee Makers & Espresso Machines
Have B70 Keurig. only getting minimum water in cup. tried blowing compressed air and reseating resevoir. after blowing compressed air resevoir water dropped about 1 1/2 inch. No running water back into resevoir. also did shake/rattle and roll. thanks
  • Slick Katz Mar 13, 2011
    did the vinegar/water thru the unit. after "ready" hit brew, brewing indicator comes on and nothing. Pushed mixture thru system by compressed air both into water intake un der resevoir and thru return valve. any suggestions?
    thanks
    did water/vinegar. indicates "brewing" but nothing happens
    thanks
    President:
  • 2,047 Answers
This happens when the unit has had too much scales from previous coffee making. Scales are those sediments from coffee which attach themselves to the body of the inner chambers of the coffee machine. Scales usually cause blockages in various parts of the unit and therefore cause the unit not to function well as it should. Refer to your user manual on best methods to use for descaling as the procedure differs from unit to unit.
feel free to request further clarifications.
Hope this solution has been helpful?
Posted on Mar 13, 2011
  • 2,229 Answers
Have you tried running a batch of water/vinegar mix through the unit? Most of the problems result from buildup of deposits. The water/vinegar mix usually does the trick.
Posted on Mar 12, 2011
The water goes back into the resevoir instead of into the cup.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 29, 2011 | Keurig Platinum B70 Coffee Maker
Not getting a full cup and also alot of water going back into the resevoir
heatman101
Jul 26, 2011 | Keurig Platinum B70 Coffee Maker
Getting the message "prime" and blue light is
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Apr 15, 2011 | Keurig Platinum B70 Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
53 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
