Question about Specialized Demo 8 I
Got a 2007 specialized demo 8 and the chain link snaped 4 times on different links and ive tried 2 different rear hubs and they keep jaming, the chain is a sram pg971
  • ldjones95 Mar 17, 2011
    they obviously do cause mine have
    Brigadier General:
  • 8,546 Answers
Chains don't just snap. Resolve the jamming and you'll have more success.
Shifting adjustment and controleld operator input will prolong the life of your drivetrain.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.sheldonbrown.com/chains.html
http://www.sheldonbrown.com/chain-life.html
http://www.sheldonbrown.com/derailer-adjustment.html
Posted on Mar 12, 2011
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
May 04, 2015 | 2006 Toyota Avalon XLS
How to change the timing chain for bmw 750 model 2007
Big job see me at www.autorepairhelp.us and will send info to you.
1131 052 - Replacing both timing chains (N62/N62TU)
1 Image ]
Special tools required:
-11 2 001 See: Toolsand Equipment/ll 2 000 Puller
-112 002 See: Toolsand Equipment/ll 2 000 Puller
-112 003 See: Toolsand Equipment/ll 2 000 Puller
-112 007 See: Toolsand Equipment/ll 2 000 Puller
1 Image ~j
Necessary preliminary tasks:
-Remove lower timing case cover See: Timing Cover/Service and Repair/Removing
and Installing Bottom Timing Case Cover (N62 / N62TU)
' Image [
Remove timing chain (1).
Remove timing chain (5).
Release screws (7).
Remove guide rails (3 and 6).
Remove tensioning rails (2 and 4).
Installation:
Maintain tension of timing chains when installing timing case cover.
Observe sparking protection on timing case cover.
Make sure timing chain (1) is correctly installed when placing it in guide rail (3).
1 Image ~j
Attach special tools 11 2 001 See: Tools and Equipment/ll 2 000 Puller and 11 2 002 See:
Tools and Equipment/ll 2 000 Puller to crankshaft.
Insert special tool 112 007 See: Tools and Equipment/ll 2 000 Puller and remove
sprocket wheel with special tool 112 003 See: Tools and Equipment/ll 2 000 Puller.
Installation:
Check sprocket wheels for wear, replace if necessary.
Heat sprocket wheel to 60 CC.
Warning!
Burning hazard! Wear gloves.
1 Image ~j
Assemble engine.
Sep 06, 2014 | 2007 BMW 750Li Sedan
Diagram timing of v6 engine of liberty 2001 model
2001 , no such ani-mule !
"Introduced for the 2002 model year as a replacement for the Cherokee (XJ),"
you meant manufactures date not model and reg. date. sure.
2002 !
3.7L V6 (cop spark ) chain drive cams....
timing ( cam or spark?)
"Ignition timing is controlled by the Powertrain Control Module (PCM). No adjustment is possible"
so Cam timing (alldata.com covers this in detail)
why not post the context, Im doing what.?
im doing a 60k belt swap
or it slipped. or think id did.
or just put in a new head or cam? see , context is 100% important.
im here, going to there.....
im on line, and it shows 4 engines, i think that is wrong, but...
you must be asking chain cam sprocket timing.
im at alldata.com (or FSM)
there are 37 install steps, im not sure what step you want me
to pluck out. but here is my guess. step 8 ,9,10
  1. Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8429 to hold chains in place for installation.
  2. Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket.
  3. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket.
step 12:
Install all chains, crankshaft sprocket, and idler sprocket as an assembly . After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or equivalent. This will maintain tension on chains to aid in installation. Align the timing mark on the idler sprocket gear to the timing mark on the counterbalance shaft drive gear, then seat idler sprocket fully . Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 25 ft. lbs. (34 Nm).
step 13:
  1. Align left camshaft sprocket "L" dot to plated link on chain.
  2. Align right camshaft sprocket "R" dot to plated link on chain.
step 15/16
  1. Remove Special Tool 8429, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
  2. Verify that all plated links are aligned with the marks on all sprockets and the "V6" marks on camshaft sprockets are at the 12 o'clock position.
do ask questions, or login to alldata.com or mitchels
or get a real FSM.
its nothing trivial.
in fact get the book before the job. so are perpared.
Nov 30, 2013 | Jeep Liberty Cars & Trucks
How do i reset the timing on 2001 2.7l concorde if the chain was replaced and the timing is off
Did you take pictures while removing the originals? It's always a good habit. Below are the instructions you need to follow. Your own pics are very helpful when doing a big job like this.
  1. Disconnect negative battery (1) cable.
  2. Drain cooling system.
  3. Remove upper intake manifold.
  4. Remove cylinder head covers, crankshaft vibration damper, and timing chain cover.
CAUTION: When aligning timing marks, always rotate engine by turning the crankshaft. Failure to do so will result in valve and/or piston damage.
117014297
  1. Align crankshaft sprocket timing mark to mark on oil pump housing (2). The mark on oil pump housing is 600 ATDC of #1 cylinder.
CAUTION: When the timing chain is removed and the cylinder heads are still installed, DO NOT rotate the camshafts or crankshaft without first locating the proper crankshaft position. Failure to do so will result in valve and/or piston damage.
117016938
  1. Remove primary timing chain tensioner retainer cap (2) and tensioner (1) from right cylinder head.
117016939
  1. Disconnect and remove camshaft position sensor (4) from left cylinder head.
  2. Remove timing chain guide access plugs (3) from cylinder heads.
NOTE: When camshaft sprocket bolts are removed, the camshafts will rotate in a clockwise direction.
  1. Starting with the right camshaft sprocket, remove the sprocket attaching bolts. Remove camshaft damper (1) (if equipped) and sprocket.
  2. Remove left side camshaft sprocket attaching bolts and remove sprocket.
  3. Remove lower chain guide (7) and tensioner arm (8).
  4. Remove the primary timing chain (5).
  5. Remove crankshaft sprocket (6).
INSTALLATION
117016940
  1. Inspect all sprockets (4,9,11) and chain guides (2,5,10). Replace if worn.
  2. For crankshaft sprocket installation procedures Refer to CRANKSHAFT SPROCKET.
  3. If removed, install right and left side short chain guides (11). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
  4. Align crankshaft sprocket timing mark to the mark on oil pump housing (3).
NOTE: Lubricate timing chain and guides with engine oil before installation.
  1. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links (1).
117016941
  1. Lower the primary chain with left side sprocket through the left cylinder head opening.
NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
  1. Loosely position left side camshaft sprocket over camshaft hub.
  2. Align timing (plated) link to the crankshaft sprocket timing mark (3).
  3. Position primary chain onto water pump drive sprocket (10).
  4. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain (8) and loosely position over camshaft hub.
  5. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
  6. Install left side lower chain guide (2) and tensioner arm (5). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
NOTE: Inspect O-ring on chain guide access plugs before installing. Replace O-ring as necessary.
  1. Install chain guide access plugs to cylinder heads. Tighten plugs to 20 Nm (15 ft. lbs.) .
NOTE: To reset the primary timing chain tensioner, engine oil will first need to be purged from the tensioner.
117016942
  1. Purge oil from timing chain tensioner using the following procedure:
    1. Place the check ball (2) end of tensioner into the shallow end of Special Tool 8186 (3).
    2. Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
117016943
  1. Reset timing chain tensioner using the following procedure:
    1. Position cylinder plunger (4) into the deeper end of Special Tool 8186 (3).
    2. Apply a downward force until tensioner is reset.
NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball.
CAUTION: Ensure the tensioner is properly reset. The tensioner body (4) must bottom against the top edge of Special Tool 8186 (3). Failure to properly perform the resetting procedure may cause tensioner jamming.
NOTE: Inspect the tensioner O-ring (2) for nicks or cuts and make sure the snap ring (1) is correctly installed, replace as necessary.
117016944
  1. Install the reset chain tensioner (1) into the right cylinder head.
  2. Position tensioner retaining plate (2) and tighten bolts (1) to 12 Nm (105 inch lbs.) .
117016945
  1. Starting at the right cylinder bank, first position the camshaft damper (1) (if equipped) on camshaft hub, then insert a 3/8 square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 inch lbs.) .
  2. Turn the left side camshaft by inserting a 3/8 square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 inch lbs.).
  3. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
117016946
  1. Activate the timing chain tensioner by using a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then release the tensioner arm. Verify the tensioner is activated (extends).
117016947
  1. Install camshaft position sensor (2) and connect electrical connector.
  2. Install the timing chain cover, crankshaft vibration damper, and cylinder head covers.
  3. Install upper intake manifold.
NOTE: After installation of a reset tensioner, engine noise will occur after initial start-up. This noise will normally disappear within 5-10 seconds.
  1. Fill cooling system.
Mar 27, 2013 | 2001 Chrysler Concorde
My 2007 BMW G650XChallenge rear wheel starts to bounce at around 100kph,the faster you go the worse it gets, have had the wheel balanced tried different pressures, different tyres and adjusted preload...
Hi, Alex I feel your pain perhaps something on this list may help point you in the right direction and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Shock absorber improperly adjusted.
15. Worn engine stabilizer links.
16. Damaged rear engine isolation mounts.
17. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
2007 BMW Xchallenge Xcountry Motorcycle USA
Thread The BMW 650 Country
2001 2005 BMW F650CS Service Manual Moto Data Project
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Nov 12, 2012 | 2007 BMW G 650 Xchallenge
Bought a 03honda cbr 600rr, front sproket had been changed out and rear tire moved back. chain is loose 2"+ in slack but i can not move tire back any further in swing arms. can I move rear tire up and...
hi, prob good idea with this will be to slacken off the wheel push the wheel forward and fit a chain the correct length for the set up you have, count the links in the chain you have on the bike and get one 2 links shorter, mark a link on the chain with paint or sim turn the wheel and count the link plates, ie 1 plate is 2 links, so start on the 1 next to the marked 1 turning the wheel counting the plates 2 4 6 8 10 etc and end on the marked 1 this will give you the number of links already on the bike
Jan 15, 2011 | 2003 Honda CBR 600 RR
I would like to have a diagram of the timing comfiguration of a 2002 dodge intrepid 2.7 .....i am very interested in the timining marks for the camshafts
Hi, this engine uses plated links in the chain to match marks on the gears. See figure and installation procedure below. Let me know if you have any questions and thanks for using FixYa.
    1. Install the timing chain by performing the following procedure:
    1. Verify that the crankshaft sprocket timing mark is aligned with the mark on the oil pump housing.
    2. Place the left side primary timing chain sprocket onto the chain, while aligning the timing mark on the sprocket to the 2 plated links on the chain.
    3. Lower the chain with the left sprocket through the left cylinder head opening.
    4. Loosely position the left camshaft sprocket over the camshaft hub.
    5. Align the plated link to the crankshaft sprocket timing mark.
    6. Position the timing chain around the water pump drive sprocket.
    7. Align the right camshaft sprocket timing mark to the plated link on the timing chain and loosely position the sprocket over the camshaft hub.
    8. Verify that all the plated links are aligned to their proper timing marks.
    1. Install the left lower timing chain guide and tensioner. Torque the bolts to 21 ft. lbs. (28 Nm).
      NOTE Inspect the timing chain guide access plug O-rings before installing. Replace damaged O-rings as necessary.
    2. Install the timing chain guide access plug to the left cylinder head and torque to 15 ft. lbs. (20 Nm).
      NOTE To reset the timing chain tensioner, oil will first need to be purged from the tensioner.
    1. Purge oil from the timing chain tensioner using the following procedure:
    1. Remove the tensioner from the tensioner housing.
    2. Place the check ball end of the tensioner into the shallow end of the Tensioner Resetting Special tool 8186.
    3. Using hand pressure, slowly depress the tensioner until oil is purged from the cylinder.
    4. Reinstall the tensioner into the tensioner housing.
    1. Reset the timing chain tensioner using the following procedure:
    1. Position the cylinder plunger into the deeper side of the Tensioner Resetting special tool 8186. Apply a downward force until the tensioner is reset.
    WARNING
    Ensure that the tensioner is properly reset. The tensioner body must be bottomed against the top edge of the Tensioner Resetting Special tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    1. Install the chain tensioner into the right cylinder head.
    2. At the right cylinder head, insert a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    3. Turn the left camshaft by inserting a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    4. If necessary, rotate the engine slightly clockwise to remove any slack in the timing chain.
    5. To arm the timing chain tensioner: Use a flat-bladed prytool to gently pry the tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner extends.
    6. Inspect and replace the timing chain cover gasket and oil seal.
    7. Apply a 1 / 8 in. (3mm) bead of sealer at the parting line of the oil pan and engine block.
      NOTE When installing the timing cover, guide the seal over the crankshaft to prevent damage to the seal-s lip.
    Install or connect the following:
    Timing cover and gasket and torque the M10 bolts to 40 ft. lbs. (54 Nm) and the M6 bolts to 105 inch lbs. (12 Nm)
    Accessory drive belt tensioner pulley
    Power steering pump
    Crankshaft damper
    Crankshaft center bolt and torque the bolt to 125 ft. lbs. (170 Nm) using tool 8191
    Accessory drive belts
    Fan module and electrical wiring harness
    Upper radiator crossmember
    Negative battery cable
    Dec 25, 2010 | Dodge Intrepid Cars & Trucks
    Can not keep chain on bar. Tried 2 different
    The inside part of the chain are called drive links. I think when the chains came off the first time (loose chain?) some of these links were slightly deformed (burred). Take a flat file to the burrs on the sides of the drive links. Once repaired keep your chain properly tensioned.
    Chain adjustment
    1. Make sure the chain brake is off (gloves will protest your fingers).
    2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
    3. Ease the tension adjustment until the chain is obviously loose.
    4. Using one hand, hold the nose of the bar up.
    5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
    6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
    Lou
    If no burrs please repost. This has piqued my interest. I think a brand new chain will operate correctly.
    Oct 31, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
    Crank knocks on my electra hellbilly when i pedal hard
    The Electra Hellbilly has a three piece crank/bottome bracket. There are many things that can cause a knocking noise on your bike. I will give you a few places that you can check but you may need to take it to your local bike shop.
    1st. Check the pedals. Take a 15 mm open end wrench or pedal wrench and makes sure the pedal are tight. Also check the pedals for any play in the bearings or tight spots. If they seem to have any issues, try a new set of pedals. Test ride.
    2nd. Make sure the crankarms are tight. Use a 14mm socket wrench. You may need to remove a cover over the nut with a small flat head screwdrive. If you have a torque wrench, they should be between 25 and 35 ft lbs. Test ride.
    3rd. Check the chain tightness. It should have just a small amount of play in the chain. Also check the chain for tight links or bad links. Do this by either flipping the bike, putting it in a stand or having someone hold the rear of the bike up while pedaling and watching for the chain to not flow over the cog in the like the rest of the links. If you find a tight link you will have the work it loose by hand, going back and forth with the tight link your hand and lubing it with something like tri-flow. Test Ride.
    4th. The last two solutions are better off adjusted but your local bike shop. You need to check the bottom bracket and rear hub. We can start with the hub. While standing over the rear wheel, move it side to side. If you feel any play then your hub is out of adjustment. Adjusting the hub requires cone wrenches so unless you have the tools it will be less expensive to have it done. For the bottom bracket, grab one of the crankarms and move it side to side, if there is any play here then it requires adjustment. Once again it requires special bicycle specific tools so it would be less expensive just to have the repair done.
    Hope this helps. Let me know if you need any other help. You can contact me at elijah@starbikesfl.com. Thank you
    Jun 24, 2009 | Pedals Electra Retro 1/2" Cruiser Bike...
    I have a 99 dodge intrepid that threw a rod and my father-in-law and I have been trying to time the car for a year now. We get number one piston up but the mark on the oil pump doesnt line up with the mark...
    I'm not sure what you may be "doing wrong", but here is the manufacturer procedure for aligning the timing marks.
    ^Refer to this diagram during step 12.
    ^Refer to this diagram during step 13.
    ^Refer to this diagram for step 19.
    1. Align crankshaft sprocket timing mark to the mark on oil pump housing. NOTE: Lubricate timing chain and guides with engine oil before installation.
    2. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links.
    3. Lower the primary chain with left side sprocket through the left cylinder head opening. NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
    4. Loosely position left side camshaft sprocket over camshaft hub.
    5. Align timing (plated) link to the crankshaft sprocket timing mark.
    6. Position primary chain onto water pump drive sprocket.
    7. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain and loosely position over camshaft hub.
    8. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
    9. Install left side lower chain guide and tensioner arm. Tighten attaching bolts to 28 Nm (250 in. lbs.). NOTE: Inspect oil ring on chain guide access plug before installing. Replace O-ring as necessary.
    10. Install chain guide access plug to left side cylinder head. Tighten plug to 20 Nm (15 ft. lbs.)
    11. NOTE:
    12. Purge oil from timing chain tensioner using the following procedure:
    a) Place the check ball end of tensioner into the shallow end of Special Tool 8186.
    b) Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
    13. Reset timing chain tensioner using the following procedure:
    a) Position cylinder plunger into the deeper end of Special Tool 8186.
    b) Apply a downward force until tensioner is reset. NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball. CAUTION: Ensure the tensioner is properly reset. The tensioner body must bottom against the top edge of Special Tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    14. Install the reset chain tensioner into the right cylinder head.
    15. Position tensioner retaining plate and tighten bolts to 12 Nm (105 in. lbs.).
    16. Starting at the right cylinder bank, insert a 3/8" square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 in. lbs.).
    17. Turn the left side camshaft by inserting a 3/8" square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 in. lbs.).
    18. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
    19. To arm the timing chain tensioner: Use a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner is armed (extends).
    20. Install the timing chain cover, crankshaft damper, and cylinder head covers.
    21. Install camshaft position sensor and connect electrical connector.
    Hope this helps!
    Mitchell
    May 16, 2009 | 1999 Dodge Intrepid
    Specialized Demo 8 I Logo
    103 people viewed this question
    Top Specialized Cycling Experts
    Christian Samuelsen
    Christian Samuelsen
    Level 1 Expert
    ddfisch
    Level 1 Expert
    John Egan
    John Egan
    Are you a Specialized Cycling Expert? Answer questions, earn points and help others
