Question about Maytag Neptune MAH7500WH Front Load Washer
Leak well after completion of wash cycle - Neptune Front Loader
The plumber couldn't figure it out but perhaps you can. Periodically and well after the MAH5500BWW completes it's wash cycle (e.g., after 11PM and before 7 AM) there is a water leak (about 1/4 to 1/2 gallon) that seems to be coming from where the drain hose fits in the drain. There is enough pressure to spray an appliance that is next to the washer and the back of the washer -- at the same level as the drain pipe opening. This just occurred while we were on vacation, had the water feeds turned off, and verified that there was no water leak after using the washer. In fact, it would appear that it leaked multiple times during the period we were gone given the amount of water. The washer appears to work great during its normal operation and there are no signs of water leaks during operation. Thanks for any suggestions! Ron
  • RGoldstein Aug 02, 2008
    Problem solved and it had nothing to do with the washer (no surprise there) -- but now is a different kind of mystery. It turns out that when the automatic sprinkler system turned on (around 5 AM) water sprayed out of the junction between the hot water shut off valve and the hot water copper pipe and caused a small flood in the laundry room floor. Turn off the sprinkler and a very slow drip could be seen and that would flow to the drain area. The plumber had no clue as to why that would happen -- especially since the water pressure would be reduced when the sprinklers were on.
  • 639 Answers
Peace,
ngafm1 at your service,
Water sprayed out of ( the leaky washers in the hot water shut off valve which need to be replaced.
They are inside all valves and wear out in time from normal use!
Or you can have a bad solder joint at the junction between the hot water shut off valve or the the pipe joint!
these washers in any shutoff valve can leak intermittently till they get worse and then leak all the time!
you should be able to stand there and watch it as you open and close the shut off valve again and again , and then stay there and watch it start leaking!
Or when you are opening it and closing the valve 4 times straight you may feel a trickle of water from the valve stem!!!!
This means washers in the valve stem need to be replaced!!!
Get a new plumber !!!!!!!!!!!!!!!!!! I'm no plumber but I do under stand this!
Bless You,
please give me a good rating here at fixya.com before you sign off!
Posted on Sep 04, 2008
I have a neptune front loader, after the wash cycle is complete the clothes smell like they have not even been wash with a **** moldy smell. I use Tide HE as directed but they still smell like i...
Hello, Thank You for using FixYa. I will be helping you today.Try 2 cups of white vinegar on a heavy duty cycle with hot water.Pour it in the detergent dispenser after it starts to fill. Also the affresh tablets work good i would use 3 tablets at one time if your unit is as bad as you say.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag Neptune MAH5500B Front Load Washer
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune fnt loader Model# MAH9700AWW
I have a Maytag neptune mah8700aww
With mine the large grey rubber seal that seals at door slipped off! When this happens if you do not put back on correctly it will leak or even poor out the front center bottom of the door! My husband fixed it. But it still leaked really bad! I just took a couple of min. to refit the seal and it does not leak at all now! maybe your seal is not placed around the edge correctly! as it is easy to place it wrong! good luck!! keep my email address if I was helpfull!! We can always share problems and solutions for our neptunes in the future ! good luck
Anne Marie
Feb 27, 2009 | Maytag MAH6500 Neptune Front Loading...
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Water leak from detergent drawer
Remove the control panel. Inside you will find a service tech sheet that will identify the error code.
There may be an obstruction in the water valve inlet flume forcing the water to travel in the wrong direction.
Jan 05, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
185 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
