Question about Nokia E71x Cell Phone
Sound very low and sound slowly come down.how to solve this prublem.
    Problem Solver:
  • 6 Answers
It could probably be bcoz your earpiece volume is low. Solution: while on a call, increase the volume by pressing the volume-up key on the side of the E71. If that doesn't help, check sound settings.
Posted on Mar 12, 2011
Low flow to the burners. Probably because of spider webs
Yes, sometimes spider webs can cause it, as well as the OPD valve in the gas tank locking up the grill's regulator. In addition, a low pressure can be caused my low fuel in the tank.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Sep 23, 2011 | Lynx L36FR (LP) Grill
My 1100lp when burners are on low flame is to low and make squeeking noise and if a slight bit of wind will blow out flame. I cleaned burner tubes and replaced regulator with factory parts will heat up on...
turn off the LP Tank, disconnect the hose from the tank and wait 5 minutes. Reconnect the hose and turn the tanl valve on very, very slowly, until it's fully open. Light each burner and turn it to high. Wait for the burners to heat up and turn them down gradually to low. If flame height on low has returned to normal, the problem is solved.
If that didn't solve the problem, the air shutters on each burner may need adjusting. Consult the installation instructions that came with the new burners for the proper setting or consult your Owners Manual.
If it's real real cold outside, it's not unusual for the burners set on low to have a problem. The only solution to that is let the grill preheat well, before turning the burners down. Also, grill with the hood closed on low, if it's a windy day.
Hope this helps you and gets you back to grilling again.
Feb 11, 2011 | Weber Genesis Silver A Grill
When starting, the motor starts sluggishly. It sounds different and goes very slowly. At higher speeds, way high, it runs fine. Speed censor says one thing, but tread moving very slowly.
Treadmills are usually made up of various components. The rolling surface (tread) is usually placed on a set of rollers when the unit starts due to the low friction between both the surface (tread) and the rollers the surface (tread) starts slowly while the rollers move regularly and the sensor is placed on the movement of the rollers.
What you need to do is get the unit serviced usually there is a way the tread it tightened to have better grip on the rollers. This method differs from one make to the other so get an expert who knows about proform rollers. Once the system is tightened the problem will be solved.
Hope this solution has been helpful?
Jan 05, 2011 | Proform 595LE Treadmill Walking Belt
Found indoor unit running and calling for cooling,outdoor unit was off and came on while hooking up to low side,low side pressure was at 0-1psi.liquid line leaving was frosted up.shut off outdoor unit and...
Hello Sounds like a restriction/clog if the unit is (pumping down) .try adding freon when the compressor cools off & starts again.See if the low side #s improve.Make sure the service valves are open.
Aug 20, 2010 | MSY-A17NA Air Conditioner
Low flow of gas to 1st burner, if second burner is turned on flame goes out. bottle full
First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 08, 2010 | Weber Genesis Silver B Grill
Low flame out put
I assume this is a propane grill. First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 07, 2010 | Grilling
Low audio level on left speaker
sounds like your left channel capacitor has slowly failed.
Jul 30, 2009 | Audio Players & Recorders
2001 ford laser Air conditioning goes on and off regardless of the setting
If the a/c is low on freon it 'll go on and off beacause off the low presure switch .
Apr 24, 2009 | Heating & Cooling
When i try to crank my car onlythe heat and the lights come on and it wont crank
Sounds Indickitive of a STARTER Prublem As Long as Battery is Fully Charged , As Strainge as it Sounds , Take A Hammer and Smack the Sterter 2-4 times and see if it starts after this If It DOES Surely it IS the Starter Even if Not It Still Can Be the STARTER Again I DO KNOW THIS SOUNDS UNCONVENTIONAL But Any Truely EXPERIENCED AUTO TECH Will Concure this is a Test for Starting Problems on Especialy Vehicles of this AGE .
Feb 21, 2009 | 1984 Oldsmobile Delta 88
Nokia E71x Cell Phone Logo
286 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
