Question about Technics SA-AX730 Receiver
Actually, I have an AX 710. I only use it for listening to FM and vinyl. The past few months, when it is powered up, it warns me "OVERLOAD" shut of and on. After numberous repeated attempts, it will generally turn on. Regardless of phono or FM stereo being last used, it will do this. Speaker wires have been cleaned (bare wire into connections at both ends) and all other connections seem to be just fine. I bought this unit used (under $100,) and it worked just fine until recently. The box sits on its own shelf, in a well circulated area. Any clues?
    Brigadier General:
  • 8,546 Answers
You know most of this....
What about heat and shorted speakers?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 12, 2011
Connecting mp3 car radio
If you radio has an Aux input then you can connect a audio cable from your MP3 player to the Aux input on your radio.
If your radio does not have an Aux input the you can use a FM transmitter device. Connect the MP3 player to the FM transmitter and tune your FM radio to the radio frequency on this FM adapter to listen to your audio book on your MP3 player.
Check out these WEB sites fro FM transmitters.
http://dx.com/c/car-accessories-799/car-audio-systems-707/fm-transmitters-players-710
http://www.amazon.com/Coby-CA-745-Wireless-Transmitter-Cigarette/dp/B000OTF6G0
http://www.popularmechanics.com/technology/how-to/gadgets/4307160
Feb 05, 2013 | Audio Players & Recorders
Any trick and number for Sony erricson r 300 for listen Fm without earphone
Hey thanks for using fixya
Actually by default there is no any trick to listen fm without earphone. If u want to listen not from he headphone, then its better that just attached the headphone with Handset, Now go in options of Radio, There is option as "loudspeaker" now you can listen fm from loudspeaker.
Enjoy
I hope it 'll be helpful for you.
Kindly keep thumbs up for rating.
Thanks
Mar 03, 2010 | Sony Ericsson R300
AX-90 NAKAJIMA TYPEWRITER USER MANUAL NEEDED
go to google type in this:AX-90 TYPEWRITER USER MANUAL
Mar 13, 2009 | Nakajima AE-710 Typewriter
Battery Get Discharged within few Minutes even after Full Charge
I have the same problem, and for now an external charger is the best solution. Also try resetting 4 times. I also got a new power supply, but problem persist. Good luck!!!
jav
Nov 19, 2008 | Kaito KA1103 SW/FM/AM Radio
Annoying crunching sound devleloped during recording
It sounds like the same problem I had. I solved it by keeping the stylus free of dust by brushing it frequently with a soft camel hair brush..
Oct 22, 2008 | ION Audio iTTUSB Turntable
Instruction manual
Trying to use the computer controlled JVC AM/FM Tuner Model FX-333.
I am attempting to use the pre-set stations desired for listening pleasure, but I have not been successful. Can you help me?
The FX-333 Tuner is linked to the AX-R441 Amp.
May 22, 2008 | Audio Players & Recorders
Technics SA-AX730 Receiver Logo
103 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
