Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
When the machine is supposed to knead, it makes a thumping noise but doesn't turn the paddles. I can't get it to knead. I've used the machine for 9 years without any problems until now.
    Sergeant:
  • 332 Answers
Some bread machines have a drive belt in the bottom see if it's come off
Posted on Mar 12, 2011
Is there anything I can do?
I don't know about your specific model, but in most bread makers there is a removable paddle that goes in the bottom of the bread pan after you put that in the machine. The paddle usually has a flattened side on the hole which slides on to the post sticking up from the bottom of the machine. If you look at the post straight down from above it should be D shaped. The usual procedure is to put the pan in the machine, install the paddle, and then add your ingredients. Assuming you are doing this and it is still not working, trying running it through a mix only cycle (like for pizza dough) with the machine empty to see if the paddle is engaging and spinning properly. If it is not, contact the manufacturer for assistance.
Aug 08, 2014 | West Bend 41053 Bread & Dough Maker
Cbk 200 does not preheat/clicking sound/doesn't knead
You may have a broken belt (not uncommon) Unplug your machine, remove the pand and paddle and turn the machine on its side. See if you can remove the metal panel on the bottom of the machine. Once you do that you will see if your belt is broken or has slipped off. It it is either of these you can reach me at breadmachineshelp.com I can then tell you how to get your belt back on or replace it.
Jan 07, 2013 | Cuisinart CBK-200 Bread Maker
Clicking noise when on the knead cycle and the kneading paddle doesn't turn at all. I have only had the machine for 1 year and no longer have any receipts.
I am having the same problem. I just purchased my machine last week. I made regular white bread last week and it worked great, but today I tried to make whole wheat bread and it froze. Any solutions for this?
Jan 19, 2011 | Cuisinart CBK-200 Bread Maker
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
When i put the ingredients as directed, i selected the program then put the delay on. when i woke up expecting fresh bread, i had a hard 3 inch brick with flour and yeast sitting on top of it. was i...
No, Everything should be done automatically. It seems that the machine did not knead the dough. Two things may have caused this. 1) The paddle is frozen and wont turn. Take the pan out of the machine and see if you can rotate the paddle by hand. If yes...that's cool, if no then the sealed bearing that the paddle rotates on is jammed or broken. Try filling the pan with warm water and let it soak. If after a few times it's still frozen, then the bearing is broken and bread pan needs to be replaced. 2) Belt fell off or is snapped. Keep the pan out of the machine and go to a kneading cycle. Look through the window on the lid and see if the motor shaft is turning. If no... the belt fell off or snapped, or the motor is broken. Good luck..Hank
Dec 03, 2009 | Oster 5836 ExpressBake Bread Maker
I have a brand new West Bend "just for dinner" bread maker. In the bottom, the two-pronged part which the motor is supposed to turn, doesn't turn. Thus, the kneading spatula doesn't turn. The heating unit...
If the machine is brand new, then take it back for an exchange. If that's not possible, then call West Bend for a replacement. If that's not possible then let's try to solve this problem in a few steps. 1) Take pan out of machine and see if you can spin the paddle on the shaft. If yes...next step..if no then bearing in bread pan is stuck. 2) Put bread pan in machine and lock in place. Start a kneading cycle. Look through plastic lid to see if paddle turns. If no step 3. 3) Take pan out of machine and start kneading cycle. If motor shaft does not turn, then the belt fell off the pulley in the machine or belt is broken, or the motor is bad
Hank
Nov 15, 2009 | West Bend 41077 Just For Dinner¿...
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
210 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
