Question about RTO Peterbilt 379 Construction Truck W/backhoe 1/32 R/c
'99 pete 379. right rear turn signal/hazzard not working. all others are fine. replaced sealed bulb assembly,not fixed. turn signal switch is good. flasher is good. no voltage to r/r signal from firewall to signal.good voltage through signal switch wiring to dash wiring.my head hurts.......any sugestions?
2 Suggested Answers
  • 19 Answers
SOURCE: where is turn signal flasher on 2000 peterbilt
the flasher is behind the left dash panel behind ur pyrometer
Posted on Aug 15, 2010
My right front turn signal on my 2001 ford ranger doesnt work and my inside right turn signal light on dash doesnt work and flashes really fast. Buld on right side was replaced and works when lights
was the correct bulb used? this sounds like a single function bulb was used NOT the bulb that will light with the headlights and ALso produce turn singles
Dec 06, 2014 | 2001 Ford Ranger Regular Cab
Turn signals stay flashing rely fast and the front ones dont turn on
When this happened to me, it ment the bulb was burned out,
Apr 09, 2014 | 2000 Mazda Protege
2001 nissan sentra neither one of my turn signal bulb are working tried replacing the bulbs that didn't work.also tried switching the pigtail that didn't work either any idea what the problem
I had this problem with my car. Is ur hazzard flasher working? if they are working and the turn signals are not working. Try replacing the hazzard light switch. If the hazzard are not working then the combination flasher unit is bad. its what controls the signals and flasher.
Nov 10, 2012 | 2001 Nissan Sentra
My 2008 Chevy Cobalt coupe has a passenger side turn signal that flashes fast on the instrument panel. However, no turn bulb is burnt out in either the front or rear. The rear passenger turn blub just...
It is as simple as your hazzard switch needs to be replaced yes your hazzard switch as now turn signals are built threw the hazzard switch my PT Cruiser had same problem as my s10 replaced hazzard switch fixed the problem
Aug 18, 2011 | 2008 Chevrolet Cobalt
'86 Shadow right front turn signal doesn't work
you may want to trace your wires to that light and check to make sure that your ground wire for that side is clean and tight that may take care of your problem all together
Jun 07, 2009 | 1985 Honda VT 500 C Shadow
99 Rodeo Right turn signal makes brake lights blink
TURN SIGNALS WILL FEED BACK THROUGH THE TURN SIGNAL SWITCH.THEY ARE INDEPENDENT OUT SIDE ON THE CAR BUT NOT IN THE SIGNAL SWITCH.REPLACE THE SIGNAL SWITCH
Jan 02, 2009 | 1999 Isuzu Rodeo
No rear brake light / turn signals on 2001 Chevy Cavalier
The problem is the turn signal/headlight/hazard switch assembly on the steering column which the brake light wiring runs through. The part is easy to change and cost about $50 at most parts stores
Jul 05, 2008 | 2001 Chevrolet Cavalier
RTO Peterbilt 379 Construction Truck W/backhoe 1/32 R/c Logo
115 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
