Sir my modem is AR800V v3.0 manufactured by fujian star net communication co.,ltd problem:-the internet lamp is not glowing and dsl lamp blinks but it should be in steady state as said by service provider.i think it is hardware problem arised when i am trying to connect my led light to 6r8m resister and since then the connection broken and isp site 192.168.1.1 i not opening.please give me hardware or software support,i am dying bcoz of it
    Scholar:
  • 97 Answers
Try rebooting the device by unplugging and reconnecting the power supply. If that doesn't help, try pushing the reset modem at the back (most modems have this) for about 30 seconds with a pen or toothpick. When neither helps and DSL keeps blinking, contact your ISP's helpdesk and check if you still have warranty on your modem.
Posted on Mar 12, 2011
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Is my modem is blinking is this normale
The POWER light should be 100% on.
The WIRELESS light should blink -- hunting for wireless devices, and communicating with them.
The NETWORK ight should blink when there is activity to/from the internet.
May 17, 2014 | D-Link DSL 200 (DSL-200) Modem
Dsl light goes beyween blinking green, then goes solid red, then back to blinking green. Cannot connect to internet anymore.
The modem cannot get a signal from your service provider. The DSL light is an indicator if your modem is communicating with the network of your service provider. DSL light should always stay solid green. Try contacting your service provider. It might also be an indication of a bad modem.
Aug 31, 2011 | Arris 221002 DSL Modem Southwest Region...
We had to have at&t reconnect our dsl service. we had disconnected the Linlsys now we can't get it to work.Help please
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Check that all the cables are correct & are connected:
* 2-wire or 4-wire cable between telephone wall-port and DSL modem;
* 8-wire cable between DSL modem and the WAN (or 'Internet') port on the router;
* 8-wire cable between one of the LAN ports on the router to the network-port on your computer.
Turn the DSL modem on, and wait until its blinking-lamps settles down to a repeating pattern.
Turn the router on, and wait until its blinking-lamps settles down to a repeating pattern.
Ensure that the lamp for the WAN connection is on.
Turn your computer on, and let it boot.
Ensure that the lamp for one of the LAN ports on the router lights up as the computer is starting.
After your computer has booted, your router should have assigned an IP-address to your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see an IP address like '192.168.xxx.yyy' for your computer,
and a similar IP-address for your "default gateway".
If you see an IP address like '169.254.xxx.yyy', then your computer has *NOT* obtained a *valid* IP-address.
Also, your router should have obtained an IP-address from your ISP (AT&T),
and you should have Internet access -- try to access 'www.CatsThatLookLikeHitler.com' (or any other web-site).
May 05, 2011 | Computers & Internet
Hi, Im using Mts mbrowse CDMA USB MODEM model ADU-200C/White manufactured by AnyData Co,Ltd. I need to unlock the modem and use other sim. Please, give me the solution. Thank You. Joseph
Thank You.
Joseph
Nov 28, 2010 | Cell Phones
I have type 4 utstarcom modem.my modem restarts now and then,dsl light goes on blinking and i loose net connection. is it the problem of modem?
hi....
this may be because
1.of the modem problem also
2.votage fluctuations.when the voltage comin to modem falls the modem gets off and when you get it right then it starts again.
3.the net gets connected only when the DSL light is glowing continously.As the modem switchs off and starts up again it takes time for the DSL light to glow continously.
if my answer was usefull to you please vote me
Jul 13, 2010 | Computers & Internet
I want usb drivers for bsnl type 2 modem. Model AR800V. plz help me.
go to this website
http://en.kioskea.net/s/Usb+drivers+for+bsnl+type+2+modem.+Modem+AR800V
and download the driver
Jun 21, 2010 | Sony PCWA-AR800 Wireless Router (c92692)
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Adsl modem not working
First you must have a steady led light on the on Power, Act and Lan, the Sync led will flash until the modem connects to the DSL line. If you are not running a router but only a modem, you will need to create a PPPOE network connection on the computer. If you are using a router with the DSL modem you will need to create the PPPOE connection only on the router. I had recently a problem with the DSL service to my home. My modem showed DSL connected but could not connect the PPPOE connection, the telephone company had to reset the circuit that I am on which fixed the problem. BPCS
Dec 06, 2007 | Acer Altos G500 Server
Computers & Internet Logo
425 people viewed this question
David Payne
David Payne
