Question about Minolta EP1083 CS/PRO Copier
I have a CS pro model 1083 with 71,000 copies on meter.It does not pick up paper. Is it worth fixing?
    Scholar:
  • 177 Answers
Yes i would have the paper pickup and feed rollers replaced you can get an estimate on the cost for parts and labour it just depends how much you are willing to pay
Posted on Mar 13, 2011
The phocotopy copy brings out a black background which was not on the original copy
if your original that you are copying is not white paper you will get this issue also another problem is that your optics mirros may need cleaning in general the machine will require a general service by a certified engineer this will fix your issue
Nov 11, 2010 | Minolta EP1083 CS/PRO Copier
Minolta CS/Pro 1031 Refuse to work and display PC
Check your paper supply in the paper tray. PC means the machine thinks it has no paper or the paper did not feed. If making sure the paper is good and loaded properly does not solve the problem then pull out the tray completely and clean the rubber feed rollers inside of the port where the tray came out off. They should be about half way to the back and over to the right side. Most common cause of this problem is dirty/dusty feed rollers that are not pulling the paper up into the machine. Just wipe them down with glass cleaner of even a cloth dampened with water.
Good Luck and Thank You for using Fixya.
Jul 14, 2010 | Minolta EP1031/1031F CS/PRO Copier
Power is on, but blades dont move
What do mean about blades not moving. The machine is a legacy minolta machine. The paper draw rollers mite need replacement. does the paper leave the draw?
Apr 10, 2010 | Minolta EP1030/1030F CS/PRO Copier
Paper jam
Call HP and replace unit under warranty.
Jun 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
Minolta EP 2050 CS Pro
This machine has been discontinued for some time now. Not sure exactly how long but I haven't seen one in the field for a while. try taking a manilla folder a manually feeding it through the same direction as the paper goes through the machine afterr pulling out the paper tray all the way to see if you dislodge any paper. Other than self remedies, it isn't worth the money for a service call.
Apr 08, 2009 | Konica Minolta Office Equipment & Supplies
Smudge on the paper
When you say smudges, do you mean toner spot or blobs of toner on you pages? If you get random blobs of toner... You need to take out the drum unit & remove the primary charge unit & remove the drum & vac. out a small little grove that seats right below the developer mag roller... It is most likely filled with toner and is dropping on to you paper as copies are being made. Good Luck
Feb 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
Is the Minolta cs pro 5000 strickly a copy machine or is it a printer too?
Im pretty sure this is an analog machine. One way to test this for sure is to make multiple copies of one original. If the light scans the paper each time, then it is a analog machine and can't be hooked up to a computer. Digital machines generally scan the document only once then print many.
Dec 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
Copier making black backgroung after 3-4 prints.
Possibly your drom is no longer discharging properly. This could be caused by bad drum, bad or dirty erase lamps.
Dec 19, 2006 | Minolta EP4000/5000 CS/PRO Copier
71 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
