Question about Kenmore Washing Machines
Won't agitate or spin, make noise as if going to work but doesn't, it spun partly one way then the other a couple of times but that was it
  • Kenmore Master
  • 2,183 Answers
You can check the motor coupling,if the coupling is good then the tranny is gone..... YouTube - Washing Machine Drive Motor Coupler Replacement (part #285753A) .......
Posted on Mar 12, 2011
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
The machine doesn't spin properly and doesn't drain the water
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Just finished washing a load and putting in dryer when I noticed the clothes were still wet. The tub was drained just not spun very well. So, I set the dial to spin and heard a motor noise but no...
hello, it sounds like to me that your clutch is going out on u and mos tlikely did . this means u may or will have to replace the motor or just pick up a used one or new one .
hope that helps.
good luck.
thanks.
veronica gillespie
May 06, 2011 | Washing Machines
Won"t spin or agitate. Makes a loud rattling noise
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Dec 17, 2010 | Kenmore 24032\24036 Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
