Question about Proview PA40JK1A 40 in. LCD Television
My proview 4000 makes chirping sounds when i turn it on. No problems with the picture quality. What could be the problem and is it worth fixing? Thanks E
4 Suggested Answers
  • 8 Answers
SOURCE: proview rx 326 model 3200 tv sound but no picture
If the sound is working, I doubt the power supply is at fault. You can check with a simple voltmeter - red is positive, black negative - there should be 24VDC. There is an on-board regulator to drop the voltage for the CPU, etc, . THere is a green LED on the main board, so even if you don't have a Voltmeter, there is a visual indication that the power supply is somewhat functional.
I found a poor connection from the 24V power supply over to the inverter boards. I re-crimped the IDC connectors to the 24V supply and all was happy-town.
Posted on Jun 05, 2008
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
Posted on Jun 22, 2009
praky16
  • 744 Answers
SOURCE: Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 07, 2009
Making chirping sound. no picture
Problem most likely on middle board----High voltage deflection board--the chirp is a primitive indicator of shutdown or self defense in these sets.
Oct 30, 2012 | Televison & Video
Where can I buy a power cord for my Proview PL456s 14 in. Flat Panel LCD Monitor?
Can you supply a picture of the connection on the back of the monitor? Try to make it high quality and put a scale, ruler or dime near the connector to give proper scale/size and I will research it for you.
Dec 01, 2010 | Proview PL456s 14" Flat Panel LCD Monitor
Tv makes loud chirping noise but does not turn on
cost i about $100 from $50 just to look at it. not really worth it especially if it reaches $300. this is a transistor problem
Dec 26, 2008 | RCA F32650 32" TV
No picture but there is sound
This may be the problem click on your remote source button and see what is checked on the blue sceen that pops up...it may be on the wrong setting... I hope this helps, Ken, Attica, NY
Nov 24, 2008 | Proview PA-32JK1A 32 in. LCD Television
Won't turn on...
first Trun up the screen, is you see vertical colapse IS because you not ertical Drive..
Jul 26, 2008 | Zenith R50W46 50" Rear Projection...
Proview 700p problem
DISPLAY IS GOING OUT SIMPLY GET NEW MONITOR
Jan 16, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
RCA F27667 No Picture / Chirping sound
I will bet you 10 to 1 that the flyback transformer and the horizontal output transistor is bad. an no at this point the set is not worth fixing.
Sep 28, 2006 | RCA F27667 27" TV
Proview PA40JK1A 40 in. LCD Television Logo
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
