Question about Dishwashers
I have a kemore model 363.14231100. Serial VF309728R.While the motor is fine, the unit no longer feeds water into the box. Is thee a part I can replace? If so, can you tell me the #, location and how to do so? Thank you
2 Suggested Answers
  • 323 Answers
SOURCE: KENMORE SEWING MACHINE MODEL 1792181
Call some local dealers and tell them what you are looking for. I,m sure one of them will have it,maybe even in stock. It's not always easy to know which bobbin case you need ( especially Kenmores) so be prepared to take in the old bobbin case or the bobbin or even the sewing machine for ready Identification.
Some helps; If your bobbin has holes all the way around then you probably have a standard case with a finger sticking up which you can get from any dealer. If you have a solid bobbin and a wrinkle finish paint on the machine you have an older machine and the dealer may have to order it for you. Be aware there are 2 different sizes of this bobbin case.You must get the right one for it to work.
sewman7
Posted on Jul 19, 2008
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Apr 30, 2012 | Miller Bobcat 3 Phase Welder Generator...
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
New kemore compact won't get cold, motor runs ok but won't turn off
If it's new (under 5 years of age) it is under factory warranty, if it's a sealed system failure. Bad compressor, refrigerant leaks, or restrictions in the connecting tubing.
Contact Sears with complete model and serial number.
Nov 08, 2009 | Kenmore Stainless Steel Compact...
Kemore washer series 80
Replace the timer.
Reply with a FULL model Number or go HERE and enter it in, and select timer in the parts menu.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kemore he3 showing f28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 23, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Boiler kept shutting down.Re-starts but drops not keeping pilot.
there ic a low water cut-off on all boilers, also a over pressure switch that can shut down the unit. You should really call a service company out to look at the problem due to the potential of a serius problem with thee unit and see whats is the problem with the unit. Boilers can explode and do allot of damage to a person and property if this happ[ens. GOod Luck
Jan 07, 2009 | Water Heaters
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
