Question about Sanyo PLV-1080HD LCD Projector
How to reset lamp counter plv-1080hd? - Sanyo PLV-1080HD LCD Projector
  • Curtis Dec 17, 2011
    Well i figured this out after several hoursof bashing my head into the wall. Take off the back cover for the lamp replace lamp of course. I forgot to reset timer and turned it off only to not beable turn it back on with it saying back light. WEll to fix this have the back cover off for the lamp. the back right theres this cross looking holes in or almost like a plus look as well. Take a philips screw driver get it to fit in the cross so the screw driver goes all the way in. Dont push hard at all litely insert it till you feel a button or click. Turn on the projector with holding the button sown with screw driver. This will force the bulb on once you do this go to the menu as usual go to settings the scroll to the third page and do lamp reset and also reset your filter settings aswell. Still make sure the screw driver is hold ing down the button then turn off the projector let it completely shut down where the red light is no longer blinking. Remove the screw drive put the cover back on make sure all screws are in or it wont turn back on. Once the screws are in the projector will turn on as it use to with normal use. Hope this helps everyone.
  • 8,197 Answers
Go to the link below page 49 - 50 will tell you how to reset lamp counter.
http://www.projectorcentral.com/pdf/projector_manual_4674.pdf
Posted on Mar 12, 2011
Sanyo plv-1080hd HAS NO POWER
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 16, 2016 | Sanyo Office Equipment & Supplies
Sanyo PLV-55WHD1 picture too dark
It may be the lamp itself, some will dim just before failing.
Average life is 2000 hours or two years for OEM lamps and much less for generic ones.
Dec 22, 2012 | Sanyo PLV-55WHD1, PLV-65WHD1 Projection TV...
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Looking for replacement lamp for Sanyo PLV-WHD1 TV Lamp type # POA-LMP96 service parts # 6103227382. Need some help finding one that is compatible for reasonable price.
You can get replacment lamps for this TV from www.TvRepairKits.com
Models Supported = PLV-55WHD1, PLV-65WHD1, PLV55WHD1, PLV65WHD1 ,PLV-55WR2C, PLV-55WR2CH POALMP96 , POA-LMP96 , 6103227382. and more.
Feb 03, 2011 | Sanyo Genuine Original 6103227382 ...
PLV-Z5 Projector, The change lamp light was flashing and closing the machine down straight after opening the slide, I changed the globe and it still does the same, I can not set/reset globe replacement...
It will continue to do this until you reset the counter. I'm not familiar with Sanyo projectors, so I'm not sure of the steps to do this. Some projectors have a sequence of buttons you push to reset it, others stay on long enought for you to go through the menu and reset it. Sometimes the new lamp comes with those instructions. If you don't still have those papers, or the owner's manual, you can go on-line to contact the manufacturer and they can tell you how to do it.
Jan 13, 2011 | Sanyo PLV-Z5 LCD Projector
Lamp for PLV-Z2000: Hello , I have a Sanyo Z-2000 projector. Aft...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 12, 2010 | Sanyo Lamp for PLV-Z2000
Looking for a POA-LMP76A lamp and price
Call Encompass Parts 1-800-638-3328 and Look on E-Bay under Electronics.
Feb 14, 2010 | Televison & Video
What is the lamp life on a sanyo plv-z2 bulb and how to read the bulb life there are 3 numbers that come up when i check it
If I remember correctly, you hold down either the power or the menu button for 30 seconds... I believe it is the power button, and it will briefly display it on the screen, but this assumes it was reset at the time the lamp was installed. The counter counts up on this model, and the lamp replace light will come on at 3000 hours. I have 2 of these units, and I have gotten at least 5000 hours out of each lamp. Toward the end of the lamp life, it may start getting dim and/or have difficulty starting, but I probably wouldn't replace it until you either notice the dimming or the lamp fails, although I've heard some say they can damage the projector when they fail, I have not had any problems.
Dec 03, 2009 | Sanyo PLV-Z2 Multimedia Projector
Just replaced the lamp on a sanyo plv-z4 and it still indicates lamp needs replacement. what do i do now?
reset your lamp counter. go to the menu find lamp setting. then reset. click OK 3 times
Oct 07, 2009 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo PLV-1080HD LCD Projector Logo
198 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
