Hi all, I've just recieved a CROLLS RT-9811 washing maching. I've notice it allways stop when the programmator reached a line separating the programs numbers. Could anybody tell me why ? Is it possible to have a description of the programs according to the function; the duration.... ? (user manual if possible) Lot tnaks. Frank +228 942 6030
    Brigadier General:
  • 6,277 Answers
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 12, 2011
  • melofranco Mar 20, 2011
    Just needing comprehension of the programs. So if anybody can help !!
  • john_cross Mar 20, 2011
    Hi again,
    In your original posting you did actually say '(user manual if possible)' and my guidance note describes how to obtain one. One reason for offering that as a solution is that there might not be any FixYa experts with a CROLLS RT-9811 available to answer you and I assumed it did not come with a manual. Sorry if I misunderstood ;-0(
    John C
Error code E35 what is this?
switch off the elec remove lid and check the pressure switch tubing is not been rubbing against the side of the mach and wearing a tiny hole into the tubing .there is sometimes 2 tubes looking from the rear of the mach they are at the left handside not the best place i normally take the rear half of the mach off to gain access .also it only needs apin hole or less to cause bother take care hope this helps
May 06, 2014 | Washing Machines
Hooking up an ipod
Are you sure you are using the audio input wires and not the audio output wires on the back of this radio. there is also an input switch you need to set before the Ipod will work
Jun 15, 2007 | Alpine CDA-9811 CD Player
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
Noticed the water level switch was kind of in between levels.. would this cause my washer to not stop filling?
It could.
The water level switch or pressure switch controls the amount of water entering the tub. It does this by pressure it recieves thru a hose. When the pressure reaches a certain level it trips the switch and signals a wash cycle. Here is a link if you still have troubles with over or underfilling testing and replacing a pressure switch
Sep 27, 2010 | Washing Machines
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
Hi I have model No WF 740 1400 spin! However programme L is filling up with water, appears to be washing as normal until it reaches final 7 minutes, then machine becomes laboured and will not spin! the...
it appears that the pump is not removing the water that is spun out  if there is a belt on the pump then it may have fallen off or need replacing   if it is intact then the pump either failed or there is a blockage in the line
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Washing Machines Logo
247 people viewed this question
Top Washing Machines Experts
