Question about QSC RMX 5050 5,000 Watt Power Amp
Qsc rmx 5050 power up but no output - QSC RMX 5050 5,000 Watt Power Amp
3 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: Please, send me a circuit diagram of QSC(RMX 2450)
hi,
its with me. if u need the same contact me on my mail.
ajingopakumar@yahoo.co.in
ok
Posted on Jan 28, 2011
  • 5603 Answers
SOURCE: amp 5050 rmx stay in
Disconnect speakers. With NO input, if clip light remains on, take in for repair as there is an internal failure. If reducing the gain and loudness keeps the clip off, then you are probably driving the amp too hard. This is common problem when the user "thinks" they need it louder but the amp speaker combination will not deliver louder. At this point, both the amp and the speakers are at risk of permanent damage requiring repair.
Posted on Sep 23, 2011
Why does it keep going into protection mode?
There are several circuits that can prevent start up, not the least of which is the power supply itself. Check the owners manual, it may tell you about conditions that could cause this. The next step is to open it up. There may be something obviously wrong, burnt, disconnected or stressed. Barring that, we'd be into board and component level testing. If you know what your doing, the output stages of these high power amps are a good place to start.
Mar 01, 2016 | QSC RMX 5050 5,000 Watt Power Amp
How to I use 2 additional qsc 500 watt power amps to push 6 jbl225x (4) ohm cabinets. I am running unbalanced stereo. Thanks, William
You don't say which QSC Amp. Assuming it is one that can only drive down to 4 ohms you are going to have to run a pair of the jbls in series for each channel of one amp (making the impedance 8 ohms for the pair) and run the other pair from the channels of the other amp. Running unbalanced is not a problem except for interference but you don't say what the source is. If you have more than one output (aux or sub bus for example or poss even a monitor output if you're not using it) it may be beneficial to take one amp from there as you will have some control over the relative levels from the mixer. Otherwise you'll just have to parallel the amps.
Nov 06, 2015 | Behringer Pmp3000 16 Channel Audio Mixer
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
How to clean volume pot on a rmx5050
Just spray a few shots but you have to take the top cover apart, then take out 3 philips screws in the pots module, take off caps and then you should be able to give'em a good cleaning spray shots.
Feb 11, 2013 | QSC RMX 5050 5,000 Watt Power Amp
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
Qsc hpr181i blow fuse
Two possibilities here, one is a cracked pin on one of the power supply UF diodes and the other one that the power output devices got fried.
Jan 30, 2013 | QSC Audio Products QSC HPR 181i
Amp 5050 rmx stay in clip mode
Sep 22, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
Please, send me a circuit diagram of QSC(RMX 2450) AMPLIFIER if you have.
hi,
ok
Jan 28, 2011 | Peavey SP2 PA Passive Speaker
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Break chanel 1 proteccion is on
Take it in for repair... this is NOT a DIY repair.
Jan 14, 2011 | QSC RMX 5050 5,000 Watt Power Amp
QSC RMX 5050 5,000 Watt Power Amp Logo
98 people viewed this question
Top QSC Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a QSC Music Expert? Answer questions, earn points and help others
