Question about Refrigerators
Hellow, hope you're having a good day. I have a kenmore refrigerator model # 596.65939401 ser# 11197289JC. The freezer is working fine, but upper refrigerator has very little cooling, I have cleaned condensor coils, reset temp control to off then to 4, checked vent behind crisper for obstructions. Frige seems to run all the time, not cycling. Damper control was replaced 12months ago because it was noisy, I can hear it operating ok. Looking forward to here from you, thanks, Dan Wilson
  • Refrigerators Master
  • 5,603 Answers
I would investigate a fan that circulates the air from freezer to the rest of the refrig.
ALSO investigate the door seals. This is a very common problem. Slide a piece of paper around the door to insure there is no gaps in the seal. The hinge settings and door fitup are important.
Posted on Mar 12, 2011
I have a kenmore refrigeator with bottom freezer. #596628322200, made by Amana. I bought it used two weeks ago from a dealer. The top started getting too warm a few days ago. The Freezer was fine. I...
Hello, Thank You for using FixYa. I will be helping you today.The defrost timer is on bottom behind the front kick plate. Open freezer door remove lower grille or kick plate and you will see it.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
My fridge is about 9 yrs. old, and I'm having problems keeping things cold all the time. It works fine for awhile and then it's like someone has unplugged it. The contents are not cold anymore, but after...
Multiple things can cause this. It could be the defrost timer is malfunctioning causing long defrost cycles. could be low on freon and freezing up causing a blockage of air flow thus a warmer than normal box. Compressor may have a start component issue where it is not coming on as designed or possibly overheating. a dirty condenser coil can also cause this issue. Good luck and hope this points you in a direction.
Aug 05, 2017 | Kenmore 73852 / 72854 Top Freezer...
Kenmore model 596.72253201. Bottom freezer works, fridge does not
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Sep 10, 2009 | Kenmore Refrigerators
My Kenmore refrigerator's top freezer unit has stop working
Is there frost on the back wall of the freezer? All of the cold comes from the freezer. The refrigerator can not cool unless the freezer is working. Either the defrost is not working or the evaporator fan is not working.
Aug 27, 2009 | Refrigerators
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works fine but no cold air in refrigerator...
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Dec 01, 2007 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
