Question about Toys
Hello, we washed parts of aprica med rev montenapoleone 27 in the washing machine and do not know how to put all the details back, can you please give us instructions? Thank you for your help and assistance!
SOURCE: Hotpoint washing machine WMA66
Thank you gittos73.
It's as gittos says. When you open the door and look inside, at the very top of the door is a white square. This holds the metal clip. If you push the little white dot in the middle of this clamp gently, it gives way and you will see the round metal clip that goes all the way round the door rubber (gasket). Remove this and you can put your fingers round the gasket and pull it toward you.
Then take the lid off the machine and you will see a 6mm nut with a spring behind it and a wire clip similar to the front one, going round the gasket where it attaches to the drum. This has a crosspoint (phillips type) head on it and you can get a small screwdriver into it and undo it all the way. Then slide the gasket off and it will come away.
Fitting it is the reverse but it is a little bit tricky as you have to get the gasket behind the lip to make the seal. Take your time and they will both go round properly.
Posted on May 28, 2008
SOURCE: washing programs.....??
http://service.hoover.co.uk/manuals/pdfs/AB100.pdf
Posted on Jun 30, 2009
SOURCE: putting it together
Goshhh I have the same problem!!! and my c-section is tomorrow and the worse thing I cannot afford to buy a new one
Posted on Jul 23, 2009
  • 69 Answers
SOURCE: what do i do
try manually moving the knob through each cycle until it gets back to the finished cycle. or the timer may need to be replaced
Posted on Jul 30, 2009
canbruce75
  • 1776 Answers
SOURCE: After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Posted on Aug 02, 2009
Fabric Conditioner part
Hello Gale.
Fixya answers will appear on this thread.
Watch this space....
Sep 23, 2017 | Daewoo Washing Machines
I need a detailed diagram for my Amana Washer model #ALW540RAW
The pressure switch sends the signal that tub is full and agitation should begin. As a rule though pressure switches are long lasting parts. Usually the problem is in the tube that goes from the switch to a bulb or box on the side of the outer drum. The hose can become disconnected, for example if machine was recently moved, or even a severely unbalanced load. Sometimes a tiny piece of lint can obstruct the hose from the bulb end.
http://www.appliancepartspros.com/parts-for-amana-alw540raw-palw540raw.html
Hope this helps.
Jan 21, 2013 | Amana Clothes Washer / Washing Machine...
LG Top load fuzzy logic washing machine only washes small loads
Please check if the drive belt to the main motor to the agitator is slipping or is loose. It is also possible that the agitator is jammed and so could have friction so that the belt slips.
Aug 17, 2012 | Whirlpool Washing Machines
Load size in Lbs. What is the maximum load my washer can handle.? Model #: GLTF2940ESO, Serial # XC53923838 purchased on Nov 9, 2005.
Hello & Welcome to FixYa
Please check these dimensions for your washer:
  • Width: 27"
  • Height: 36"
  • Depth: 27-3/4"
  • Approx. Product Weight (Lbs.): 204/217
  • Approx. Shipping Weight (Lbs.): 217
Please get back to me if you have any other questions.
Kevin
Jul 16, 2011 | Frigidaire Washing Machines
Hello, our whirlpool keeps washing and washing, never getting to the next cycle. thx for help.
Hello there:
The most common problem with this is that the timer is failing and will not allow the machine to go to the next cycle
So what you are going to have to do is to take off the back panel and remove the wires that are attached to the timer (this is the part that you select the different cycles from ) better know as the timer ok?
then remove the knob and remove the timer and replace it than hook up the wires back into the new one and put the knob back on and the test the machine ok? and hopefully you will be good to go from here:
I hope this is very helpfull for you
Best regards michael
Dec 16, 2009 | Whirlpool Washing Machines
Maytag FAV6800AWW - Major overflow right after starting machine
Hi, If you turn the water source valve on and water starts filling the machine even tho the machine is off, change the inlet valve.
If you have to start the machine so water will fill but, the water does not shut off at the desired level, there is a problem with the water level switch.
I hope this helps you. Please let me know if I can assist you further.
Vic.
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Sticks half way thro programme
found the problem,unplug machine pull out remove back cover screws look in side machine,there is a black pipe on right hand side bottom of machine,that is the drain pipe to the pump,remove jublie clips and check for blockages,mine was blocked refit cover and put machine on normal cycle to clean,
machine works fine now,
Jan 26, 2009 | Candy AQ130 Front Load Washer
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Toys Logo
62 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
