Question about Mtd Products Yard Machines 158CC Tiller
My MTD rear tine riller model 21aa412a352 will only go in reverse. Any suggestions?
  • 10865 Answers
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Posted on Feb 27, 2009
SOURCE: broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Posted on May 13, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
I had this same problem and took the first advice about the shift fork arms being too spread apart. I took apart the gearbox apart and found that the shift fork arms did indeed spread apart overtime and with wear. I'm having a buddy weld some reinforcement to it as long as he can maintain clearance in certain areas as to not disrupt the operation. If it doesn't work then I did find the shift fork assembly part for $50, I just googled the part number, clicked on various sites, and found a better price!
Posted on Mar 03, 2010
  • 10 Answers
SOURCE: MTD yard machine model#216-410-000
either your tine shaft is seized to bushings which requires total dissassembly of unit or you have a failure of drive chain or gear i'm currently repairing one with the seized bushings if you are not a technician i would recomend replaceing unit very costly to repair in any case.
Posted on Apr 12, 2010
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
How to operate sears5 hp rototiller. Especially the gear shift. Has reverse
Hi and welcome to FixYa, I am Kelly.
Find the long model number on your tiller. Then go to this site: http://www.managemylife.com/mmh/owner_manuals
Enter your model number and searh for you manual. When the manual is found click get manual or rt click the manual you want Owner, Engine, or parts and download it. The instructions will be in the manual.
This is an example of a model number: 917295852 and the manual for that rear tine tiller is here:
http://www.managemylife.com/mmh/owner_manuals/86874/CRAFTSMAN-Rear-Tine-Gas-Tiller-1006404L?brand_name_search=917295852
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Mtd Garden
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Mar 20, 2011 | Mtd Garden
The cluch doesn't work. The gear pointer doesn't
Do you have a model number? Front tine or rear tine? I will try to help you.
May 29, 2010 | Mtd Products Yard Machines 158CC Tiller
I have a MTD yard machine rear tine tiller. Goes forward and reverse but tines wont rotate. How do I fix?
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Apr 30, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd rear tine garden tiller . The wheeles will engage and turn forward and reverse but the tines will not engage. At first they would but would pop out of gear. Now they w9ont engage at all.
Could be the shifter inside the gearbox or it could be a stripped gear or broken chain. The bad news is you will have to remove the gearbox from the engine and then open the gearbox to see what is going on. This is quite time consuming but taking to a shop for this is very expensive due to the labor involved. You can do it yourself if you pay attention to how you take it apart. I hope this helps you out.
Apr 04, 2010 | Mtd Bronco Rear Tine Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Tines wont turn
Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
Apr 16, 2009 | Mtd Bronco Rear Tine Tiller
Broken clutch cable connector, MTD Tiller
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Need manual for mtd 5 horse rear tine tiller model 135202 need to know how to change chain
Feb 27, 2009 | Mtd Bronco Rear Tine Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
132 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
