On the dash board it appears with is writing: Malfunction Detected, inform the service representative for the error code
  • Todd Whiddon Mar 12, 2011
    We need you machine model number please.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Whats the make and modle of the machine? Also what are the numbers that fallow Malfunction detected.
Posted on Mar 13, 2011
Hi can anyone help correct error code E7 10 on asharp AR 5516S copier
It's one of those dealler faults..
"Turn off the power switch, wait about 10 seconds, and then turn on
the switch again. If this does not clear the message, write down
the code (Main code and sub code exists.) that appears and then
unplug the power cord and contact your authorised service
representative. Tell your authorised service representative what
code appeared and the circumstances under which it appeared."
from the following link..
https://www.manualslib.com/manual/601912/Sharp-Ar-5516.html?page=74#manual
Feb 26, 2017 | Office Equipment & Supplies
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
Code malfunctios c1441 minolta di 450
The copiers CPU is equipped with a self diagnostics function that on detecting a malfunction,gives the corresponding malfunction code on the touch panel.Resetting a malfunction:
- Press the trouble reset switch on the technical representative setting switches board to reset fusing and exposure lamp related malfunctions.(code: C400,410,420-expo;C500,510,520-fusing unit)
- For any other malfunctions,open and close the front door or turn OFF and ON the power switch.
C1441 CCD failure(clamp adjustment failure).
Reset the malfunction,check that the original glass is properly installed.Check for extraneous light and check to see if CCD Assy and mirrors are installed at the correct position.If the same malfunction is detected again,change image processing board.
Aug 14, 2012 | Office Equipment & Supplies
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Hi, our oce variolink 2822c suddenly began to show; "malfunction detected. inform the service representative of the error code", trouble code: c- 3721. Unfortunately service representatives...
Your machine is made by Konica Minolta. The C3721 code means that your fuser unit has detected an overheat condition. The fuser unit is the assembly that uses heat and pressure to "fuse" the loose toner onto the paper. It is located right where the copies exit the machine. Your are going to need to have your local service company come out and make repairs. You may get advice as to how to reset the code but beware. Since this is an overheat code, if you reset it more than once you can do severe damage to your fuser unit. You may turn a simple and relatively in-expensive repair into a major one.
I would waot if at all possible for the service technician, but I have only worked on Konica Minolta copiers for nearly 28 years now.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 22, 2011 | Office Equipment & Supplies
The gauge in my yamaha fz6 2006 is blinking, the manual says there is a electrical circuit problem. I check all the ligths nad fuses and they seem in order, what else could it be?
I believe you count the amount of blinks to read the codes. First blinks are first number, and second set of blinks are second number. Chaz Moto DC
Fault Code: 12
Symptom: No normal signals are received from the crankshaft position sensor.
Fault Code: 13
Symptom: Intake air pressure sensor-open or short circuit detected.
Fault Code: 14
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
Fault Code: 15
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Fault Code: 16
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Fault Code: 19
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Fault Code: 21
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Probable cause of malfunction: Open or short circuit in wiring harness.
Defective coolant temperature sensor.
Malfunction in ECU.
Improperly installed sensor.
Fault Code: 22
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Defective intake temperature sensor.
Malfunction in ECU.
Fault Code: 30
Diagnostic Code: 08
Symptom: The motorcycle has overturned. Probable cause of malfunction:
Overturned.
Malfunction in ECU.
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction: Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Fault Code: 34
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Malfunction in ECU.
Fault Code: 41
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Defective lean angle cut-off switch.
Malfunction in ECU.
Fault Code: 42
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Fault Code: 43
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Probable cause of malfunction: Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Fault Code: 44
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Probable cause of malfunction: Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal. Probable cause of malfunction:
Malfunction in "CHARGING SYSTEM".
Fault code: 50
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Probable cause of malfunction: Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Probable cause of malfunction: Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
Fault code: Er-2
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Probable cause of malfunction: Improper connection in wiring sub lead.
Malfunction in ECU.
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Malfunction in ECU.
Fault code: Er-4
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Malfunction in ECU.
Feb 23, 2010 | 2005 Yamaha FZ6
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 03, 2009 | Office Equipment & Supplies
Hi there!!! My printer displays error message: malfunction detected call representative - c3751. Kind regards
hi this is a high temp code, you need to replace the fixing unit then get a service tech to reset the machine
si
Jun 05, 2009 | Konica Minolta bizhub C250 All-In-One...
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
System Error: Code E000 Product manual: Turn off for 10 minutes. "if you cannot solve the problem" "call your service representative" I don't have a service rep. Please help. David717
I posted a note with a contact number..this appears to be a service level request
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products inactive_ln.gifcall_small_off.gif800-828-4040us.gifinactive_r.gif
Mar 13, 2008 | Computers & Internet
27 people viewed this question
k24674
jasbo
jasbo
